Okay guys so I’m parting out my car. The motor set up has about 500 miles on them and a few runs at the track. Everything is in great shape. Ideally, I would like to sell the motor and transmission first since the whole car is still complete.
Either way I will make some videos of the motor running and date it as I will not hold onto any parts, so everything is for sale and ready to go.
Parts will be taken off after I receive payment… I will accept paypal, venmo, or zelle. Preferably I would say paypal will be the best for both parties.
Prices won’t include shipping or paypal fees.
Also, please give at least a day or two to pull the parts off as they sell, I’ll get everything shipped out within 1-3 days.
If you guys need any pictures, please feel free to ask.
Shell:
1988 FC RX7
Clean Title
Mini tub, can fit a 325/50/15 Drag Radial
Ford 8.8 Rear End (Narrowed)
Strange Spool
Moser Axles w/ C-Clip Eliminator Kit
5 Point Roll Cage
Kirkey Aluminum seat w/ valid Seat belt Harness
Aeromotive 15Gal 340 Stealth Fuel Cell & Pump P/N: 18664
Radiator w/ High output Delray Fan
Manual Power Steering Rack
Grannys Speed Shop Solid Mount Kit
Shell does not have wipers, a/c, or heat
Interior is removed
Headlights, signal lights, brake lights are all in tact and working
All of the fabrication on the shell was done by JW Racing in CT
$5000
Engine:
2005 LQ4
Complete Rebuilt Bottom End – Everything is standard bore, nothing was oversized.
Wiseco Flat Top Pistons w/ wrist pin eliminator kit
Callies Forged 4340 Rods w/ arp screws
ACL Race Bearings
Stock Crank – Blasted & Polished
ATI Super Damper
AFR 230 Heads w/ upgraded 8019 Springs
ARP Head Bolts
LS1/LS2 Single Roller Timing Chain
Cosmetic Head Gasket 4.160 Bore X .040
Yella Terre 6645 LS Rockers 1.7 Ratio
Manton Custom Length Pushrods 11/32 X .125
Custom Comp Cam 235/242
MOTOR MADE 478WHP/416TQ
Dyno Sheet will be provided
Motor comes bare with no accessories, will included whatever sensors go on the long block.
$5500
Trans:
T56 Magnum P/N: TUET11009
T56 aluminum bell housing
Tick Performance Remote Clutch SPEED Bleeder
$2500
ACT Extreme Twin Stage 1 Clutch w/ Flywheel (LS1/LS2/LS7)
ARP Pro Flywheel Bolt Kit
$500
PST 3.5" Carbon Fiber Driveshaft (T56 input, Ford Output) (38-3/4" Length)
Strange U1669 1350 Trans Yolk
Strange U1630 1350 Pinion Yolk
$600
Harness:
PSI LS1 Standalone Wiring Harness (DBC) P/N; HAR-1013
EV6 Injectors (LS2/LS3 Type)
3 PIN MAF
Manual Transmission (T56/T5/TR6060/NV4500)
FBody Coolant Temp Wiring
No A/C, No Oil Pressure Hook up
$350
Fbody PCM
$125
Fuel:
FIC LS2 42LB Injectors w/ 1/2 Top Kit with 14mm Lower
$300
Holley Fuel Rail Kit P/N: 534-209
$100
Aeromotive FPR P/N: AEI-13109
$120
Accessories:
LS1 Alternator
$90
LS1 Starter
$90
Meziere Electric Water Pump w/ Harness P/N: 680-WP319S (Chrome Finish)
$450
FAST LSXR 102mm Cathedral Port Intake Manifold (LS1/LS2/LS6)
$750
FAST 102MM Big Mouth Throttle Body (DBC)
Includes TPS & IAC
$175
JTR 1-7/8" Long Tube Headers
$750
