Hello, my 1988 Rx7 had a brake line leaking towards the rear, so i ran new brake lines and fittings in the rear of the car. Since i had all the lines out i took off my calipers and had them powder coated. When i assembled everything back onto the car, i tried to bleed the brakes and got fluid out of the rear bleeders, however the front were bone dry. I cracked the front lines loose at the master cylinder and had no fluid coming out there either. So i ordered a oem master cylinder and bench bled it with steel lines to ensure no air getting sucked through the fittings. When no more bubbles came out of the master i installed it into the car and the same thing is happening. I even left my bleeder lines hooked up and watched fluid come out of every port individually. So then i hooked the car’s brake lines back into the master and i am still getting no fluid to the front when i crack the front lines at the master. I am stumped. Any help would be great
