Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Search
Recent Posts
Gallery
Search
Stats
Login
Register
This topic
This board
Entire forum
Google
March 31, 2025, 07:36:39 PM
Technical Information
Forced Induction/Nitrous
Looking for a FMIC without modifying front rail/support
Add to Reputation:
I agree
I disagree
Comment:
« previous
next »
Print
Pages: [
1
Author
Topic: Looking for a FMIC without modifying front rail/support (Read 2948 times)
driftnfb
Staged
View Gallery
on:
May 01, 2021, 09:05:55 PM »
I’m looking for suggestions on a 750HP-850HP FMIC. I’m considering a V Mount setup for My radiator due both the turbos position. Keeping the rail and core support intact is very important to me in routing these pipes. I’ve searched a few build threads and every setup is unique, some have fabricated their own.
Any suggestions would be sweet
Logged
1994 Mazda RX-7
LS2, T56, Twin Turbo Comp 6061 Air-cooled Madness, Ronin 8.8
driftnfb
Staged
View Gallery
Re: Looking for a FMIC without modifying front rail/support
Reply #1 on:
May 02, 2021, 08:20:31 AM »
I’m realizing this is probably a tough question , I have looked at the treadstone IC and other vertical Flows.
Logged
1994 Mazda RX-7
shainiac
Launching!
View Gallery
Reply #2 on:
May 02, 2021, 05:00:51 PM »
I think if you use a vertical flow, you'll have a hard time not modifying the rad support. I have a 12*24" vertical core with the charge pipe over the short 16" tall core radiator and had to remove the radiator support. Are you running single or twin turbos?
Logged
'88 TII - Rods/Pistons LS3, Twin G30-770s, MaxxECU Pro/PDM
BMW DCT Swap, Ronin 8.8" IRS
driftnfb
Staged
View Gallery
Reply #3 on:
May 02, 2021, 08:39:34 PM »
Twin. The turbos are low in the bay. I think I’ll have to get the radiator in first and see what I got. The car will have AC Con Also
Logged
1994 Mazda RX-7
shainiac
Launching!
View Gallery
Reply #4 on:
May 03, 2021, 08:03:48 AM »
Here's a shot of my intercooler/rad setup. Also running low mounted twins. FWIW, this is in an FC.
Logged
driftnfb
Staged
View Gallery
Reply #5 on:
May 03, 2021, 08:18:13 AM »
Looks good and definitely close to my plan. Looks like you have a decent amount of space left. My idea is similar (and talking with tictakman) is to use that space between the crank and rad fans as a vmount. If it’s slid back some the top feed intercooler style should flow right into the TB. I’m going to see if I can modify the samberg V2.
Logged
1994 Mazda RX-7
shainiac
Launching!
View Gallery
Reply #6 on:
May 03, 2021, 08:31:10 AM »
The issue I saw when tilting everthing back like that was that you lose space to run proper intakes. I saw a decent increase in injector duty cycle when I went from intakes behind the rad fans to properly ducted intakes that draw air from the bump. It also drove better in traffic and made more consistent power.
Logged
kinger
Launching!
View Gallery
Reply #7 on:
June 18, 2021, 09:39:42 AM »
You guys are so talented to fit all of that in there! I look at my NA set up and scratch my head like how the heck are they fitting turbos, ICs, larger Rads, intakes, into this space LOL.
Great job!
Logged
Print
Pages: [
1
« previous
next »
Jump to:
=> Forced Induction/Nitrous
