March 18, 2025, 10:57:22 AM
Author Topic: SOLD* Turbo LS1 FC Drag Car  (Read 2154 times)
Offline Rcfifty1
« on: April 12, 2021, 01:26:37 PM »
*SOLD*
Features-
-Hinson subframe modified to position engine 2" back.
-Cromoly 8 point roll cage done by David Lemmond at Race-Fab.
-Autometer gauges
-Innovate wide band
-Lingenfelter LNC 002 controller
-Mazda manual steering rack
-Turbo 2 rear end
-Centerline Drag pack with M/T Et streets
99' LS1- Diamond Pistons, K1 rods, Eagle forged crank, ARP head studs, ARP main and rod studs.  317 heads with light chamber polish, PAC .660 springs, Comp pushrods, Melling oil pump
Comp 228/232 608/615 114lsa cam.
Precision 6765 turbo, Tial 44mm wastegate, Racegate BOV, Greddy boost controller.  Meziere 55gph H2O pump.   Edelbrock Pro Flo intake manifold with Nick William's 90mm throttle body.
-Powerglide- Red devil manual valve body, hardened input shaft, Alto steels/clutches, PTC 3200 stall converter, B&M ratchet shifter.
Currently the car has the turbo kit off to re-do the hot side.  The previous setup made 707hp/615tq. at 15lbs with 93 octane so it works fine.  The sale will include everything to re-install the original setup.  As well as any progress made on the new hotside.
Asking $6500
Located in Raleigh, NC.  Email motorsportsmechanix@gmail.com with serious inquiries
« Last Edit: May 22, 2021, 08:42:59 AM by Rcfifty1 »
Re: Turbo LS1 FC Drag Car
« Reply #1 on: April 23, 2021, 11:09:05 AM »
The cagework alone is amazing on this car.... somebody buy this... slap in an 8.8" solid axle setup and go run 9's.
Offline Rcfifty1
« Reply #2 on: April 24, 2021, 11:11:21 PM »
Thanks!  The cage is definitely very well done.  I do have a solid 8.8 that I can get my hands on if a buyer wanted.  Had it lined up to put in soon.
« Reply #3 on: April 24, 2021, 11:28:43 PM »
Wish this was closer!
Offline Rcfifty1
« Reply #4 on: April 26, 2021, 11:00:05 PM »
I would be willing to help with transport within reason.  Cant go across the country but I could drive a few hours to help a serious buyer.
Offline Nephilim
« Reply #5 on: May 19, 2021, 08:58:55 AM »
Is this still available? I may be interested
