March 17, 2025, 01:26:33 AM
Author Topic: Connector between firewall and glovebox/ dash. Help  (Read 1679 times)
Offline strickrothp
« on: June 06, 2020, 02:07:34 AM »
I bought my car already swapped and was working around my passenger footwell area and accidentally pulled this purple wire and yellow wire out from this connector. Would anyone know which wire goes where and what they might be for?
I ran out of daylight and couldn't really troubleshoot what problem i may have caused.
Edit: NVM. After doing some research I believe this is the X-14 connector and the wires are for the coolant temp and vehicle speed sensor.
« Last Edit: June 06, 2020, 06:09:22 AM by strickrothp »
Offline Gunnytron
Re: Connector between firewall and glovebox/ dash. Help
« Reply #1 on: June 06, 2020, 10:23:52 AM »
This might help you identify and trace where they may have come from. You may just have to follow the loose wires to their source.
http://grannys.tripod.com/3C8instructions7.html
http://grannys.tripod.com/3C8instructions8.html
In any case, them falling out that easily is pretty poor workmanship.
Offline Turbotronic
« Reply #2 on: August 27, 2020, 04:25:38 AM »
I'm doing the wiring in my car right now. This was extremely helpful, thank you.
