March 17, 2025, 01:43:55 AM
Author Topic: FD LSx swap subframe - RONIN's design  (Read 58976 times)
Re: FD LSx swap subframe - RONIN's design
« Reply #150 on: June 09, 2020, 06:26:23 PM »
If and when you start offering a radiator setup, I have the CAD setup I used to make mine if you're interested in using it as a starting point.
Offline Daniel1286
« Reply #151 on: June 09, 2020, 08:10:59 PM »
Please make a radiator setup, it would be an instant buy for me
Offline braintumor
« Reply #152 on: June 10, 2020, 01:35:32 AM »
[/quote]
We'd still be glad to talk to you as you do the swap.  Free shipping offers have all been taken.  We wanted to celebrate the launch but we have too much time invested in these to do it for everyone unfortunately.
[/quote]
well poop, $70 on shipping is a bit more than I wanted to spend :(
the builders subframe says mounts are unwelded, but it does come with them to be welded on by me right?
Offline MerkLs2
« Reply #153 on: June 10, 2020, 01:52:43 PM »
Seconded.
93 FD BB • 6.0 LSx • Ronin Subframe • T56 Magnum •  Terminator X
« Reply #154 on: June 10, 2020, 02:27:37 PM »
Seconded.
3rd.
Offline evoforstevo
« Reply #155 on: June 14, 2020, 12:29:41 PM »
« Reply #156 on: June 15, 2020, 01:27:18 AM »
PM sent.
Offline MerkLs2
« Reply #157 on: June 19, 2020, 03:11:48 PM »
Mine arrived a few minutes ago, everything looks great!
Offline Kewin
« Reply #158 on: June 24, 2020, 03:01:44 PM »
Still waiting for the guy who ordered to install on his 2JZ Swapped  :-[
Offline braintumor
« Reply #159 on: June 30, 2020, 12:18:17 AM »
got mine today! looks great! 1JZ here we goooooo
Offline Kewin
« Reply #160 on: June 30, 2020, 09:39:26 PM »
Can you update us with it? I'm waiting for someone to do it before I purchase it myself since I don't live in the states and It will be a hassle if it doesn't work.
2jz FD here with tech2 kit
Offline braintumor
« Reply #161 on: June 30, 2020, 11:52:18 PM »
of course I will. finishing up the 2.5RS currently and will get started on the 7. have the wiring specialists plug n play harness, r155 trans with 1j/2j bellhousing adapter etc. now I need the time to get to work on it.
« Reply #162 on: July 22, 2020, 04:05:07 AM »
Just following up.  If anyone has feedback or suggestions for us based on your kit, please drop a line to roninspeedworks@gmail.com.  We're getting set to cut the next batch.  Oh, and a bit delayed, but I've been working on install instructions for both the overall and steering kits so we'll have those available shortly.
-Joel (for RSW)
Offline braintumor
« Reply #163 on: July 26, 2020, 12:06:28 PM »
-Joel (for RSW)
yes actually, the sack of bolts that came with it. would be great if there was a pic reference sheet/bolt location guide for where they all go (figured some of them out, wasnt sure if should remove FD subframe studs so didnt). other than that it was pretty straight forward and the caster/camber channels were great!
also, would you happen to have or be developing a "builders" trans crossmember like the subframes you sell? basically a bare bar that comes down from the highest FD mounting point, 90' degree then across to the other mounting points, just without the t56 mounting points? am very interested in this as I'm sure others are as well.
« Last Edit: July 26, 2020, 08:48:22 PM by braintumor »
« Reply #164 on: July 26, 2020, 10:02:22 PM »
The two mounting points in the tunnel are for a cross brace and only spot welded in. Some have used them in the past. They usually tear out.
