March 16, 2025, 02:30:58 PM
Author Topic: FD LSx swap subframe - RONIN's design  (Read 58960 times)
Offline Esser
Re: FD LSx swap subframe - RONIN's design
« Reply #165 on: August 07, 2020, 12:41:10 PM »
I have a strange desire to get this new subframe even though mine works perfectly fine. I just want a project haha
« Reply #166 on: August 12, 2020, 04:43:46 AM »
Install instructions posted both for the subframe and steering bits (plus updates to the 8.8 instructions since I was at it).  I'd like to get some better pictures but with travel restricted we still wanted to get things live post haste.
http://www.roninspeedworks.net/index.php?route=information/information&information_id=7
Offline Kewin
« Reply #167 on: August 24, 2020, 04:03:57 PM »
got mine today! looks great! 1JZ here we goooooo
yo man, did you ever get the 1jz on?
Offline braintumor
« Reply #168 on: September 05, 2020, 01:06:27 PM »
I did, engine and trans in. now how to get it on my lift once the subie is off it to mock up engine and trans mounts. hood closes with stock Jpipe still on. trying to post pics to this reply arnt working
« Reply #169 on: September 06, 2020, 03:55:14 AM »
You probably need to reduce their size to under 1000kB.
Offline Kewin
« Reply #170 on: September 07, 2020, 12:38:25 PM »
If you have time, I think you can upload to IMGUR or Google docs then share the link here! Would love to see the pics
Offline braintumor
« Reply #171 on: September 12, 2020, 08:10:56 PM »
I went ahead and started a new thread in the intro section with pics, they worked lol. didnt want to hijack this thread. thanks ronin speedworks for the awesome subframe. and let me know when you guys get a trans mount option for me!!
Offline Esser
« Reply #172 on: September 17, 2020, 10:49:15 AM »
I'll probably be ordering one.
Question about your 8.8 kit.... I would like to order one, but i already have the axles. And I dont plan on using the bushings in your kit, im going solid on all of them. Any way I can just order the rest separately?
Thanks
Offline Tictakman
« Reply #173 on: November 29, 2020, 07:20:48 PM »
I got around to installing my new K member this weekend into my TT V8 Rx7.  Overall, it fit like a glove...  Initially I was worried about my turbo parts not fitting anymore but I was pleasantly surprised that everything cleared just like my Samberg K member.
One question for Joel, I installed the steering seats for the rack and cannot use any shims because the power steering hardline is just about touching my pan (fbody).  Little concerned about this....any ideas?
Overall, great job on the execution so far!
Zak
« Reply #174 on: November 29, 2020, 09:36:47 PM »
Any chance your motor mounts have sagged a bit?
Zak
« Reply #175 on: November 30, 2020, 04:01:01 AM »
Best guess would be sagging motor mounts.  I'd toss a 3/16" spacer on top of the biscuits between those and the pedestals.  There doesn't seem to be any harm in running them after they take a set but it's still better to maintain some clearance to the rack.  Make sure whatever you use for a spacer has a much surface area as possible.  I actually just did this to my FC and I used a hole saw and some 3/16" aluminum.
Offline Tictakman
« Reply #176 on: November 30, 2020, 07:20:35 AM »
Ya, possibly.  Ill do it!
Thanks,
Z
Offline Esser
« Reply #177 on: November 30, 2020, 12:54:08 PM »
Do the C5 corvette alum mounts still work with new subframe?
Any height differences between using your fabricated mounts vs c5 mounts?
Offline fastfalcon94
« Reply #178 on: December 09, 2020, 11:27:41 PM »
Zak
I had the samberg subframe too and swapped it out for the new Ronnin one. I did the "subframe only" meaning I re-used the samberg stuff (bump steer, trans mount, steering column spacers etc..). The Samberg steering column spacers were too tall and the line coming out of my rack would also hit the oil pan. I had to machine the samberg steering spacers down to 10mm thick so the rack would drop lower for proper clearance. They were 20mm tall originally. I understand the main spacer that comes with the Ronnin bump steer kit is 10mm and then they include some shims.
Also for anyone wondering, I swapped the subframe with the motor in the car. I put the car up on jack stands and used a floor jack with a piece of plywood under the oil pan to support the motor. When I machined my spacers down I made an exact copy out of wood (so 20mm thick) and kept running them own my table saw until I found what worked. If you buy the Ronnin bump steer kit you wouldn't have to machine anything.
Offline RX7what
« Reply #179 on: April 20, 2021, 02:58:49 AM »
Wow guys. These look really good. Do you guys stock these now? Whats the lead time for one? How you guys been?
PER AUDACIA AD ASTRA
