March 16, 2025, 02:42:58 PM
Author Topic: 79 Mazda RX7 SA with turbo 302  (Read 3144 times)
Offline jmoffitt
« on: October 24, 2019, 10:13:51 AM »
1979 Mazda RX7 SA with turbo V8 swap
Other than some rust in the front driver’s wheel well, the car is solid for its age. The intent was to build a fun street / “Hoonigan” / drift / drag car. I simply enjoy building cars and it’s time to let this one go. The car consists of the following modifications and parts:
Engine
•   NEW Granny’s SBF and T5 swap kit
•   Low mileage Ford 5.0L / 302 roller motor pulled from a late 90s Explorer
•   GT40 3 bar heads
•   NEW CSU Blow Thru E85 carburetor
•   Edelbrock Victor Jr intake manifold
•   NEW Alex's Parts valve springs
•   NEW Elgin E1018P camshaft
•   NEW FireCore50 spark plug wires
•   NEW NGK BR7EFS spark plugs
•   Fox body oil pan and pick up tube
•   NEW 3 row aluminum radiator
•   NEW 180* T stat
•   Volvo fan, relay, and BMW temp controller
•   NEW 10AN catch can setup
•   NEW starter
Drivetrain
•   World Class T5 transmission
•   NEW T5 Steel bearing retainer
•   NEW bell housing plate
•   NEW clutch fork
•   B&M shifter
•   NEW performance clutch
•   NEW pilot and throw out bearing
•   NEW Wilwood clutch master cylinder
•   NEW Wilwood slave cylinder
•   NEW custom aluminum driveshaft with Spicer joints
•   Shortened Explorer 8.8 rear with 31 spline axles, disk brakes, and 3.73 LSD
-   NEW axle seals
-   NEW parking brake shoes and hardware
Turbo
•   2.25” Hotside
•   4” Fender exit
•   Spectre carb hat
•   NEW BBK shorty headers modified and TIG welded to fit with v band connections
•   NEW VS Racing “S366” turbo
•   Twin VSR 44mm wastegates
•   VSR 50mm blow off valve
•   NEW billet vacuum block
Ignition & Fuel
•   MSD 6530 ignition box
•   MSD 2 BAR MAP sensor
•   MSD HVC-2 coil
•   NEW 10 gallon aluminum fuel cell
•   AN fittings and lines throughout
•   NEW 380 LPH fuel pump
•   NEW 8AN 40 micron fuel filter
•   NEW 8AN 100 micron fuel filter
•   NEW Aeromotive boost referenced FPR
Suspension, Brakes, Wheels, & Tires
•   NEW Ground Control front coilover conversion with 300# springs
•   NEW Moog K9369 idler arm
•   NEW Mazda 8871-49-101 steering column bushing
•   “PB&J” rear suspension modification
•   NEW KYB shocks and struts
•   NEW master cylinder
•   Manual brake conversion
•   NEW brake lines
•   NEW brake pads all around
•   (2) NEW 15x7 Rota RB wheels up front
•   (2) 15x8 rear wheels
•   (4) NEW Achilles ATR Sport 2 195/55R-15 tires
Miscellaneous
•   NEW Jegs racing seats
•   Fresh gaskets throughout
•   Gauges
-   Powerdex AFX wideband with new sensor
-   Vacuum/boost
-   Tachometer
-   Voltmeter
-   Oil pressure
-   Fuel pressure
Comes with custom TIG welded steering knuckles modified to increase steering angle as well as a new pair of Ground Control 200# rear springs.
$6,900. Clean title in hand. No joy rides and no trades. Located in Columbus, OH.
PICS: http://s293.photobucket.com/user/jmoffitt88/embed/slideshow/79%20RX7
« Last Edit: November 11, 2019, 09:57:20 AM by jmoffitt »
Offline jasonv31
Re: 79 Mazda RX7 SA with turbo 302
« Reply #1 on: October 24, 2019, 12:08:15 PM »
Wow... This car sounds amazing!  Can't wait to see the pictures of it.  Great work on the parts list... I likey haha [emoji6]
Sent from my ONEPLUS A6003 using Tapatalk
Offline jmoffitt
« Reply #2 on: October 28, 2019, 11:18:50 AM »
Thanks man, pics in the link: http://s293.photobucket.com/user/jmoffitt88/embed/slideshow/79%20RX7
Offline jmoffitt
« Reply #3 on: November 11, 2019, 09:58:16 AM »
$6,900
Offline 13btoy
« Reply #4 on: February 10, 2021, 08:30:22 PM »
I know It's been a while since this was posted but is this still available?
Thanks, Ed
