Soooo, I can’t seem to shake this fuel issue. After a few minutes of run time, my main fuel pressure starts to drop off significantly.
The car will start and run cold with approx. 44psi base pressure, pressure rises and falls like it should with the FPR (goes down with vacuum, goes up if I pump shop air into the regulator).
See the diagram below-
I have a Walbro 450 (Pump A) in the main tank as a lift pump feeding the surge tank.
In the surge tank are two genuine AEM 380lph pumps.
One AEM (Pump B) is on when the engine is on.
The other AEM (Pump C) is turned on only under boost. Pump C is isolated by a check valve so it does not back flow when only Pump B is running.
Pumps B and C also tee together and feed the engine with 8AN PTFE line. All the line is PTFE braided and I haven’t ran any ethanol through the system. Pump A and Pump B are powered by Dorman 902-310 PWM fan relays whenever the engine is running/priming. I’ve set duty cycle to 100% all the time. Initially it was set to 50% DC and upping to 100% seemed to extend how long it would run before crapping out.
Pump C is powered by a Bosch 30A relay.
Fuel pressure readings are taken at the Aeromotive FPR with a transducer.
I guess it’s worth mentioning that all the pumps prime and make pressure when bench testing, it only seems to be an issue after the engine has been running a while.
Between Pump A and the surge tank I have a very large spin-on 10u filter. Between the surge tank pumps and the engine I have another inline 10u filter.
What I’ve tried so far:
Replaced the in-tank Walbro because I thought the surge tank may be going dry.
Replaced the spin-on fuel filter
Swapped Pump B and Pump C positions (kept check valve correct to isolate inactive pump).
Replaced the relay wiring to all 10AWG w/ 30A fuses.
The problem still seems to be the same.
Here's the only pic I could find of the surge tank installed:
