You can't run a Vette regulator with boost, it won't reference.
When you run a forced induction setup, you need to boost reference. Here's why:
Right now your injectors put out say, 50# of fuel per hour at 58 psi of pressure behind them and somewhere between -10 and 0 PSI in front of them (in the engine). If you turbocharge it and put, say, 10 PSI into the engine side, now your effective fuel pressure is only 48 PSI, meaning your injectors flow ~41# of fuel per hour. As you need MORE fuel, you get less. The solution is a boost referenced regulator that adds 1 PSI of fuel pressure for every pound of positive plenum pressure (aka boost). This means you now put 68 psi behind the injector at 10# psi of boost, meaning effective pressure at the injector outlet is 58 psi. It also means that under vacuum it flows less, which can make tuning low throttle behaviors a little easier and making big injectors just a little easier to manage.
Hope that helps.
