March 18, 2025, 05:25:01 PM
Author Topic: Hydaulic fluid?  (Read 1213 times)
Offline phoenix
Hydaulic fluid?
« on: September 27, 2018, 05:42:17 PM »
So I've heard some people mention replacing the atf with hydraulic fluid to "tighten" a loose converter. Has anyone on here tried it and if so what type fluid did you use. I know it would just be a patch for the real issue, But I'd like to see if it helps my short time. Thanks.
Offline phoenix
Re: Hydaulic fluid?
« Reply #1 on: October 01, 2018, 11:15:49 AM »
thanks guys. once again you have been a big help.
Re: Hydaulic fluid?
« Reply #2 on: October 01, 2018, 12:00:20 PM »
What answer are you looking for?   The best advice for adjusting fluid to work with your converter/transmission setup is to hit up the transmission builder or converter builder.
Some types of tractor hydraulic fluid (I used to run Hy-Guard) will tighten the converter, but it may also jack your clutches if they're not compatible.    Depending on what components are in your converter and transmission, the answer can vary quite a bit.
All that said, yes, I ran the Hy-Guard because it tightened up my 4800 RPM stall for driving around on the street.  It also had a big temperature tolerance before "burning".   That was in my Rossler 'glide.
-Blake
