March 31, 2025, 04:31:53 PM
Author Topic: Cooling turbo after car shut off  (Read 3823 times)
Offline ZekeO
« on: July 23, 2018, 12:46:14 PM »
What's the best way to keep the fan running after the car shut off?
A capacitor? How much would be needed to run an average radiator fan for 5 mins?
'93 RX-7
'04 M3 Convertible
Offline jwvand02
Re: Cooling turbo after car shut off
« Reply #1 on: July 23, 2018, 03:09:52 PM »
Keeping just your rad fan running isn't going to do anything.
Most commonly you use a turbo timer, which actually just keeps the whole car running for a few minutes to circulate oil/coolant.
« Reply #2 on: July 23, 2018, 06:29:40 PM »
Is it water cooled or just oil cooled?
« Reply #3 on: July 24, 2018, 10:06:46 AM »
If you just want to run the cooling fan after key off, and you've wired your fan relay properly, it's a tuning setting in the ECU.
Offline ZekeO
« Reply #4 on: July 24, 2018, 09:20:14 PM »
It’s both oil and water cooled Garrett.
That’s awesome to know that Megasquirt ultimate can keep
The fan on.
'93 RX-7
'04 M3 Convertible
Offline onefastrx7turbo
« Reply #5 on: September 27, 2018, 01:55:00 PM »
even running the fan will basically just cool the water in the radiator and likely will not have enough effect to cool the turbo. Many VW/Audi cars had small pumps run after the key is off to cycle coolant through turbos.
1989 RX7 - for sale!
1993 RX7 - waiting to be reborn
2010 RX8 - new DD
Past rides......
Offline jwvand02
« Reply #6 on: September 27, 2018, 03:23:30 PM »
The fan on.
If you're also running an electric water pump and can keep that on the same timer as the fan, you might actually be in business. Water has to circulate for it to have any significant cooling impact. But like I said, what you really need to use is a turbo timer, which is a purpose-designed thing for this exact application.
« Reply #7 on: September 27, 2018, 04:31:08 PM »
At the end of the day, just don't beat on you car for 30-60 seconds before shut off.   Or if you're drag racing or whatever, let it idle for 30-60 seconds.    This is what a turbo timer does.   It's not hard to be a human turbo timer.
Offline Grumpy
« Reply #8 on: September 27, 2018, 07:41:58 PM »
That what we do with our Buick V6 Turbos. no big deal. Even at the drags by the time you get back to the pits we shut it off.
Dan
AKA "Sleeper6"
9.999 @ 135.96
Buick GN V6 Turbo
8.8 Ford rear end. 308 gear.
200 R4 with a LU converter
Drag Radials
3324#s
