March 18, 2025, 05:42:49 AM
Author Topic: I want to replace the ls1 in my fd  (Read 1751 times)
Offline mrspider
« on: July 22, 2018, 03:05:16 PM »
What is the most Up to date engine i can fit in my rx7 fd is the lt1 of C7 corvette can be used?
Envoyé de mon H3123 en utilisant Tapatalk
Re: I want to replace the ls1 in my fd
« Reply #1 on: July 23, 2018, 08:10:59 AM »
Someone on here is doing a gen VI LT1 swap on here, I think custom subframe though
Offline shainiac
« Reply #2 on: July 23, 2018, 09:44:58 AM »
IMO, there's not much benefit to doing a Gen5 swap.
To get the direct injection to work, you'd have to integrate the stock ECU which would be a huge pain in the ass. Waaaay more difficult than splicing in a LS1 harness from a Camaro if even possible.
You can buy a MSD intake manifold that fits these engines and has provisions for port injection. In theory, you could run without the DI and use an aftermarket ECU. Crank/Cam trigger pattern is the same as GenIV, so it wouldn’t be that difficult as long as you didn’t want DI. But you’ve now added a $1600 intake/throttle body to the parts list and a standalone ECU.
The GenV motors have pretty decent flowing cylinder heads, but not markedly better than stock LS3 heads or ported cathedral port heads.
GenV motors also use the same rods as the GenIV/LS3, except for the Z06/ZR-1 which use a factory forged powdered metal rod and forged piston.
The GenV also as VVT and has a fuel pump lobe on the cam that keeps them from being backwards compatible with GenIII/IV engines, so cam selection is much more limited. The stock LT1 pistons are also 11.5:1. Pump gas driving is going to require conservative timing and careful tuning without DI.
I’m not 100% sure if the oil pan bolt pattern has changed, but that is also a concern. I doubt that the new Camaro pans would fit well in an FC/FD without being too low and I
Moral of the story, buy an LS3/T56 Magnum and spend your extra cash on good ancillary parts.
BMW DCT Swap, Ronin 8.8" IRS
« Reply #3 on: July 23, 2018, 09:52:05 AM »
 DI can also give you carbon buildup problems on the valves and in the ports. They dont get washed with gas like port injection.
