March 18, 2025, 05:43:11 AM
Author Topic: Can you V8 swap a RHD RX7?  (Read 1735 times)
Offline FourAces
« on: June 19, 2018, 04:41:58 AM »
Was thinking the transmissions for the LS by and large tend to be for LHD American cars. So in its regular configuration, an American V8 swap/transmission would be awkward as hell in a RHD RX7 to shift with your left hand going far left for first gear and 2nd, and gradually working your way back towards the right. Or am I overthinking this?
Spotted this one for sale, why I had to ask. Some of the JDM cars coming from overseas are really nice examples of the vehicle.
https://www.japaneseclassics.com/vehicle/1993-mazda-rx7-efini/
Re: Can you V8 swap a RHD RX7?
« Reply #1 on: June 19, 2018, 05:34:01 AM »
Sure you can.    And transmissions in Japan aren't different then here, first gear is in the same place.
Quite a few Brits and Aussies on here.
Gunnytron's is a good reference:  http://www.norotors.com/index.php?topic=12880.msg176042#msg176042
Same with 4packet:  http://www.norotors.com/index.php?topic=9956.msg138254#msg138254
Some others here also, clutch master cylinder is one of the main annoyances.
« Reply #2 on: June 19, 2018, 09:21:07 AM »
RHD vehicles in England have the same shift pattern we do here.
It takes a few minutes to get familiar with it, but it soon becomes nearly as natural as using your right hand.
I still think the pattern is optimized for, and works a bit better for right hand shifting.
Offline Gunnytron
« Reply #3 on: June 19, 2018, 01:48:31 PM »
Yep, there's a few over here. Give me a shout if you have any more questions.
Things to note when doing a RHD, you have less room for the brake slave, headers aren't easy to get hold of (though I think Ronin are working on some), and RHD wiring diagrams are pretty much non-existent.
