March 18, 2025, 04:37:05 AM
Author Topic: T56 Speed sensor pin outs?  (Read 2404 times)
Offline BNR34RB26DETT
« on: February 06, 2018, 08:11:20 PM »
T56 speed sensor question. I'm using stock ecu and pin out on red side calls out for pin 20 VSS low and 21 VSS High. How should i wire up the t case ss? So I hook up the green pin 20 wire and ground the other? Pin 21 cable came cut off.
-CZeroMedia
LS6 FD Build Video Series :drive:
Re: T56 Speed sensor pin outs?
« Reply #1 on: February 06, 2018, 10:31:11 PM »
I take it that's a 1 wire sensor?   If so, that should work in theory.   Stock sensor is two wire, obviously.
« Reply #2 on: February 06, 2018, 10:34:21 PM »
its a two wire. im assuming one goes to VSS high and other to VSS low but im just confused as to why the purple wire is cut on the ECU side......
« Reply #3 on: February 07, 2018, 09:32:57 AM »
They're sometimes tapped for something like a Dakota Digital.  Not sure why it'd be cut though.
Offline onefastrx7turbo
« Reply #4 on: February 07, 2018, 03:53:43 PM »
Pin A on the connector is light green/black and goes to ECU pin 20. Pin B is purple/white and goes to ecu pin 21.
1989 RX7 - for sale!
1993 RX7 - waiting to be reborn
2010 RX8 - new DD
Past rides......
« Reply #5 on: February 08, 2018, 07:22:44 PM »
awesome! thank you
