March 18, 2025, 06:15:04 AM
Author Topic: New Holley "Mid-Mount" drive kit + Turbo Manifold  (Read 5399 times)
« on: December 11, 2017, 09:10:38 AM »
Have you all seen this?
https://www.holley.com/products/ls_power/ls_and_lt_accessory_drives/complete_accessory_kits/parts/20-185
Saw it at PRI last weekend and it's a pretty slick setup, VERY tight to the engine and could probably work well with some turbo setups also.   Considering it's all new parts and complete, the pricing really isn't bad either.
They also had this:
https://www.holley.com/products/ls_power/ls_exhaust/ls_exhaust_manifolds/parts/8510HKR
Which was probably my favorite new LS thing there.    Built in high flow log style crossover manifold for turbo setups.    Pretty freaking slick and it should fit an FC/FD pretty easily.
Re: New Holley "Mid-Mount" drive kit + Turbo Manifold
« Reply #1 on: December 11, 2017, 11:21:08 AM »
Awesome to see someone like Holley embracing the turbo game like this. Great stuff.
Offline 65imp
« Reply #2 on: December 11, 2017, 12:01:35 PM »
both of these are really sweet.  Next Turbo LS will def. use the manifold.
93 FD widebody - destroked
72 Blazer - 6.0, 6speed 4wd
65 Impala - 5.7
59 cad  - 5.3
53 spartan - crash pad status
« Reply #3 on: December 11, 2017, 12:57:25 PM »
That manifold is awesome.  I like how it goes around back and frees up more space up front.  With all the holley front drive stuff plus the manifold that has to be record for compact physical space and power output?  Its like a 2.5 cubic feet making 1K+hp.
« Reply #4 on: December 11, 2017, 02:35:26 PM »
They have an improved version of the Sniper EFI intake that's pretty nice too.   The old ones were 'looks cool' but not very useful for big power or anything, the new ones look pretty stout.   I'm pretty impressed with the stuff that Holley and Edelbrock had, in particular.    Not much Coyote goodies though, sad for me.  LOL
Offline Gunnytron
« Reply #5 on: December 11, 2017, 04:22:45 PM »
Where would the crossover go?
« Reply #6 on: December 11, 2017, 04:37:55 PM »
Both those products are sweet, Blake did you get to see Mike Finnegan's 55?
« Reply #7 on: December 11, 2017, 04:52:29 PM »
Gunny, under the transmission.
I didn't see Blasphemi.   If it was there I missed it somehow.
Offline Gunnytron
« Reply #8 on: December 11, 2017, 05:19:21 PM »
Ah, OK. I didn't think there would be good enough ground clearance on an FD for that. Only reason I asked.
Offline Dyesuperman
« Reply #9 on: December 11, 2017, 06:27:39 PM »
If there is sufficient ground clearance, that's an amazing setup for these cars. If I go turbo I'll likely get both of these. Wish I could do it now!
Offline talkstometal
« Reply #10 on: December 12, 2017, 11:21:59 AM »
I dont even have a car (right now) and I want to buy that header setup!
Offline carlb
« Reply #11 on: December 12, 2017, 12:23:44 PM »
I think there's ground clearance for the crossover but then no space for the downpipe. Maybe through the fender then?
Sent from my SM-G955U using Tapatalk
'93 RX-7 Black ~500hp
Forged LS2, MMS 220 Heads, 227/230 114+3, Ported FAST 92
Magnum F, Mamo RPS BC2 Clutch, Ronin 8.8 / 3.55 LSD
Ohlins DFV, RaceLogic TC, RB Dual Tip Exhaust
Offline carlb
« Reply #12 on: December 12, 2017, 12:37:01 PM »
Maybe room ahead of crossover though, but it'll be a close thing. I'm intrigued now [emoji41]
« Reply #13 on: December 12, 2017, 12:41:14 PM »
Where in the heck are you going to fit a crossover under the trans? Scrape city.
Offline carlb
« Reply #14 on: December 12, 2017, 01:08:17 PM »
Scrape city indeed. Need to get it back on a lift to see if any option exists. I'm not planning on a turbo so this is idle speculation for me.
