Alright so started in on the control arm dissassembly, and like I said to get to some of the control arm bolts on the chassis you really need to pull the undertray. The whole car has a flat underside, consisting of 3 aluminum sheets, and the diffuser.
So I figure while that stuff is down I'll change the oil, like I said in my last post.
I pull the undertrays, no problemo. get the car up high on stands.
Get under there and see that the car has an aftermarket pan on it. Nice piece!
Aluminum pan with a nice drain plug. Drain the oil and it looks old, and then I say after the fact... ohh I should run a magnet in the drain pan and it picks up all sorts of metal fragments.
So I begin to freak out a bit, but remember I didn't clean that pan out so I don't know if they came from the oil or it was just dirt that fell on the drain pan and was there already.
See below for the drain pan, you can see all the pieces in the shiny oil. I'm still freaking out a bit inside because I'm not sure if this came from the engine or it was there:
So I decide I need to pull the pan and see what's at the bottom of the pan
Takes me 5 minutes to pull the bolts and 3 hours to work a putty scraper all the way around to break the seal from hell held in place with some whicked RTV:
So I pull the pan, and it's a nice trapdoor pan like the one I had for the rx7.
But I put a magnet down into the bottom of the pan swirl it all around the bottom of the pan and I 2 small metalic items are stick to it about the size of a small grain of sand... Hmm still left a bit wondering if that crap came out of the oil or not....But it seems a lot cleaner in here than outside.
I dump the rest of whats left in the pan into the drain pan and I notice some red/orange globules, they don't feel like anything just can't figure out what they are so I took some pics:
Any idea what those might be, like I said I see them, and they stay together on their own but I can't feel them.
Well anyway I got to the job at hand, and unless you guys tell me otherwise, my thought is to throw some new oil in it, run it the rest of the summer unless I run into issues and then pull the pan again this winter when I rebuild the car and see if there's anything new in the pan.
Thought this was interesting, where the front of the control arm mounts to the chassis. It actually bolts to a removable box that then bolts to the frame in 4 spots, making the suspension parts, part of a modular system so you can ruin the rim, ruin the control arm, even ruin the mount and still unbolt it from the chassis. I'm sure the rim and control arm are designed to fail before the mount, which is designed to fail before the chassis. I really really like the way this car is built, it's more race car than road car. I do not dare touch my daily driver, or my wife's, but again, this car makes sense to me. In a ton of ways it's just like the rx7 (I know I've said this before)
Everything is unbolted the control arm is just connected to the spindle at the ball joint. Just need to seperate them, and the lower control arm should fall right out. Then need to seperate the ball joint for the toe link and it should fall right out too. So I can replace them:
So I'm leaving this up to the crowd smarter than myself. should I just throw some oil in it and go, or should I pull the windage tray and pull some of the rod bearings. I've never done it, but it seems pretty idiot proof. Rod bolts should be right there once I pull the windage tray.
