Fixed the radio, which was bothering me a lot more than you might imagine. I track 12v power from the radio fuse all the way to a set of relays under the dash, which are FUCK-ALL hard as hell to get to.
I hated getting udner the dash of the FC, this car is a nightmare under there. if you get claustrophobic at all, this would not be the job for you.
So I'm trying to figure out why the radio/Radar dectector/Wideband are all dead. They're all right next to each other and obviously on the same circuit because everything else is working in the car.
So I trace 12v the whole way, to the radio, and I pull the harness for the wideband and check continuity of the ground wire there (figuring they also probably use the same common grounding point, or at least if they don't and it's a grounding issue than one should be working and not the other)
Grounds are good, it's getting power, now I'm thinking the relay is bad, and it is tucked up under the dash, so I'm in the passenger seat, in my driveway (to use the sunlight so I can see) with my feet sticking out of the roof and my head under the dash with the car running to burn off the last bit of the old gas.... ohh what my neighbors must think
Finally I remember that the last jackass tried to jump start the car, and I see some of the hex bolts holding the trim around the column is still loose. So I pull it... thinking there's no way that the radio's key on power is driven directly from the ignition column (that would be too simple)
Take it all off and low and behold one of the connectors is off the terminal on the ignition.Plug it back in turn the key and the radio/wideband come right on.
Lol
This car may have some specialty parts but it's AWESOMELY simple for a 2006. It's really no more complex than my Rx7. All the relays are you standard looking square type that you'd find on a race car, everything is driven off the ignition. The RX7 really prepared me well for this car. I thought I'd be jumping into uncharted waters with such a new car, but it's old school under the hood.
Still tryin to figure out the radar detector but that's not a project for this summer.
Things left to do before I get this on the road
-Install new turn signal light - light gets here by end of week
- get insurance - should hear back from grundy in the next couple days ($333 / year to insure this car, no limit on miles)
- Got the specialty tool (lug key) from the dealer to pull the lugnuts finally, so now I can pull the wheels and get the tires mounted and balanced. Might have a bent rim (it's deff heavily scuffed and the lip is slightly bent, but if it's straight and it holds air, it'll do for the summer)
- Need to move the oil cooler on the side that got hit in the front. it got pushed back and is making contact with the front tire at full lock, will need to bend the mounting tabs back out, or take it out all together. I've had 2 race teams tell me the stock dual oilcoolers actually never allow the oil to come up to temp, so pulling one is actually a good idea.
- Fix the drivers side window, it was supposedly repaired but it's off track and jammed. The motor works but the window gets crooked halfway up the track and jams. Will also need to adjust the windows to fit flush with the soft-top which is coming today.
As long as no other surprises come up, I should be on the road, potentially next week
