Thank you for the info! I'd bookmarked that calculator a while back but had forgotten about it.
I scaled my car a couple years ago with the 5.3L+EFR turbos, S195 knuckles/brakes, and air-air intercooler. I think net weight of the W2A is pretty close to zero, but 6.2 and new turbos might be slightly heavier?
2022 weights
LF: 800
RF: 795
LR: 736
RR: 721
Total: 3052
Cross: 50.2%
Left: 50.3%
Front: 52.2%
For yucks, I also have a photo of the car scaled with the 13BT, stock TII trans/diff, big single turbo, W2A IC, and single exit 3” exhaust.
I’m not 100% sure that the scales were under the correct wheels, though.
2015 weights
LF: 634
RF: 729
LR: 763
RR: 654
Total: 2779
Cross: 53.5%
Left: 50.2%
Front: 49.1%
I added 60# to each of the LS corner weight (driver weight) and entered it into the calculator. I also upped the unsprung weight. For each corner, the tire/wheel is roughly 50#, 30# of brakes, 30# of strut body, knuckle, control arm.
The antiroll bar info was a bit confusing. There’s no input for bar ID, so I used my spreadsheet to get a solid bar to match the same rate as a 1.125”X0.083” bar. 0.91” OD.
The roll resistance from the bar is 2X that of the spring, which surprised me.
I think 350# springs front and back will be a good starting point.
Also, as if I didn't already have enough ADHD projects, I’m working on swapping late model Toyota GR86 seats into my car. I picked up a driver-side seat on eBay for cheap and chopped the OEM slider off of the seat mounts.
I was able to match the OE brackets up to 3 of the 4 holes on the Mazda OE sliders, but the seat is scooted pretty far inboard and hard to slide. The Toyota seats have 4 shoulder bolts that hold the stock brackets/sliders in from the side and act as pivots for the tilt feature.
My plan is to scan the Toyota seat mounting points + Mazda OE sliders and have some brackets laser cut and bent. As-is, the seats sit a bit higher than the stock TII seats, but without a sunroof, it’s not too bad. I’m sure passenger side will be worse, since that seat sits higher from the factory because of the cat converter hump in the floor. Hopefully with everything scanned, I can check seat bottom clearance and drop them a bit more.
They are super comfortable and have way more lateral support than my 37 year old TII seats. There’s also about 10 different flavors of color and material options from 13 years of FRS, BRZ, GT86, and GR86. The GR seats I bought are black cloth and don’t look too bad, but there are some nicer color/materials. I've always been a fan of OEM seats from a comfort, safety and material quality standpoint. I street drive the car far too much to deal with fixed back buckets. OEMs also use higher quality materials that are more resistant to wear and UV in my experience.
If everything fits well after I make brackets, I may consider selling them for people looking to do this swap.
