Turbo kit is DONE! Well, sort of.
I finished the passenger side yesterday. It all fits, but required a little ticking of the frame rail. I test fit everything multiple times when tacking, but I think this side moved a decent bit after final welding.
At first, the wastegate moved too close to the manifold. After cutting and re-fitting, it's literally thousandths of an inch from the frame rail. BFH and good to go
The other thing I'm kicking myself about - The passenger turbo is a few degrees cocked to the right. I made one last adjustment, cut off tacks, retacked, and used a level to square the turbo to the manifold on the bench. Not sure what happened, but it ain't that straight lol. After the waterpump, radiator and balancer/belt are on, I'm sure it'll be less noticeable, but it bugs the hell out of me. I had the change to get it right and just missed it lol. The height left-to-right is also different, but that's more of a factor of the manifolds not actually being symmetric.
I've ordered oil drain fittings and hose and putting together a shopping list for downpipe materials now. Planning on buying all my stainless from AceRace instead of my usual questionably-magnetic eBay "304". If anyone has recommendations for affordable quality mandrel bends, I'd love to hear em.
Once I'm able to mock up the drain lines, I'll pull the engine back out, weld the bungs to the pan, seal everything back up, and put the engine in for the last time (hopefully).
