Minor update – car has been running great. I’ve been daily driving it the last few weeks. I think I went 2 weeks without even starting my daily driver Lexus lol.
I’m still chasing EMI issues with the DCT. The speed sensor for the DCT output shaft is a 2-wire VR sensor. The nice and expensive harness I bought for the DCT is all DR-25, Tefzel, and concentric twist, but they didn’t bother to use shielded wire on the speed sensor.
Apparently the majority of their customers have no issues with EMI, but I’m one of the unlucky ones.
It currently doesn’t effect drivability, but the DCT controller manufacturer keeps teasing a new closed-loop update that would use the speed sensor as one of the parameters and should greatly simplify tuning. The car drives pretty well as-is, but there are a few spots that could be better with more time and effort tuning open-loop.
This weekend I redid all the grounding an power for the battery, ECU, GCU, etc. I ran new 4AWG from the engine block to the battery, new 4AWG power from battery to just ECU/GCU (preciously shared with starter/alt), ground for GCU/ECU straight to battery.
I noticed these changes did have some improvements in voltage stability. It previously had +/- 0.5V of variation when the engine was running, and now less than 0.25V. Noise on the DCT speed signal is exactly the same. A buddy also lent me his 2-year-newer HTG GCU and that also had the same noise, so it’s not the GCU.
Another annoyance – the car started running at 205-210F consistently. I could still hear the fan running (PWM at 100%), battery voltage was fine and the coolant level was fine. Turns out one of the Ford Contour dual fans crapped out. I was able to verify the PWM controllers and wiring were fine, just one fan no longer works. Ordered another fan and can hopefully just swap the motor/blade into the modified shroud I currently have installed.
I also have started sourcing parts for the LS3 turbo kit. I was planning on using Pulsar G30-770 twins. They’re Garrett clones for about 1/3 the price and come in reverse rotation for mirror-image hotness.
Leaving the EFRs for a Garrett knockoff had me a little worried, but they’re supposed to make great power (not that I need or can use a ton more). Luck was on my side and I ended up finding a Indycar EFR 7163 on eBay. Now I need to find a second unit.
The EFR 7163 is the 57/56mm version compared to the 54/51mm EFR 6758s I currently have on the 5.3. It should mimic the response and spool of my current setup, just +20% power. Borg Warner also sells “SX-E”-style compressor covers for the EFRs, which have 4” inlets instead of 2.5”, and anti-surge slots. I don’t have issues with surge on spool-up, but they do get surgey if I back off the throttle, but don’t go into enough vacuum for the BOV to open. Also, more whistley noises. Someone with a ~500whp STI swapped from the standard EFR comp cover to the SX-E and picked up like 40whp and 30wtq on the same tune. Seems like a no-brainer.
EMI, blue is DCT output shaft speed, green is engine RPM. DCT output should be a smooth line at stead speed, but you can see all the little blips that are signal noise. the duration of the spike is basically just 1 period of the signal refresh rate, but it still makes the DCT's calculated VSS worthless for traction control.
New EFR
