After 10+ years as a full blown rotard, I finally bit the bullet and decided to go V8. Over the past year, I built a 540whp 13B setup that had been dead nuts reliable, lots of fun, and pretty damn fast. Pump gas and water injection worked great, but I had no room for error at those power levels. I commuted the rotary setup 400+ miles a week and the 13mpg and 2-stroke oil were more than annoying too. I felt like I was a bit on borrowed time, so I quit while I was ahead and sold everything before it blew up. I really wanted a fast, fun, and reliable street car without the inconveniences of a strung out rotary.
Goals:
500+whp on pump gas every-day tune
700+whp on race gas or ethanol for SlipStream roll racing events
20+mpg average
A drivetrain that I won’t have to constantly worry about exploding
Engine:
2009 GM LC9 5.3L w/ ~70k
Aluminum block
799 casting LS6-style cylinder heads
Stock rods and pistons
New stock head gaskets and ARP head bolts
Brian Tooley Racing 0.660" lift dual valve springs
Brian Tooley Racing "Stage 2" Turbo cam (226/231 .605"/.598" 113+4)
LS6 intake manifold
Dual Walbro 400s, Bosch NGI-2 2200cc injectors
ICT Billet accessory brackets for power steering and alternator
Turbo Stuff:
(2X) Borg Warner EFR 6758s – Used Indycar Turbos (54mm inducer -53lb/hr each)
(2X) 44mm wastegates
Dual 50mm BOV
Stock truck exhaust manifolds and SCH10 304SS for the turbo hotside
On3 24x10x3.5” core twin turbo intercooler
Radiator/fan TBD
Drivetrain:
Tremec T56 Magnum, wide ratio
Monster LT1-SC twin disk 1000whp clutch/fw
Ronin Speedworks 8.8” IRS swap, 3.73 gears? (TBD)
Strange 3” Chromoly Driveshaft w/ 1350s
Body:
Shine RE-spec front end with 90mm HIDs
Shine carbon sunroof delete
Megasquirt MS3PRO-Ultimate ECU/Plug and play wiring harness
