March 18, 2025, 06:03:08 AM
Author Topic: Simple question - which port is inlet on LS1 water pump  (Read 3880 times)
Offline Gunnytron
« on: September 25, 2016, 07:25:22 AM »
Believe it or not I can't find this information out. I looked on pirate4x4 but their pics contradict each other.
So which of the 2 ports on the LS1 water pump is the inlet (from heater) and which is the outlet (to heater)?
Ta
Re: Simple question - which port is inlet on LS1 water pump
« Reply #1 on: September 25, 2016, 10:04:41 AM »
Bigger port toward front of engine is flow to the heater. Small is return.
Offline Gunnytron
« Reply #2 on: September 25, 2016, 12:46:10 PM »
Nice, thanks.
Offline radiomike
« Reply #3 on: September 25, 2016, 01:26:06 PM »
Did you use the existing rhd heater hard pipe, if so the hose at the heater end is almost perfect for water pump to hard pipe?
« Reply #4 on: September 25, 2016, 04:22:20 PM »
Does it make any difference which direction the coolant flows through the heater core?
I think I routed my outlet to the outboard port at the firewall, just because the hose routing is cleaner.
My heater output isn't much in winter.  I had attributed it to the 170 degree t-stat not letting the motor get fully warmed up.
« Reply #5 on: September 25, 2016, 07:38:57 PM »
Should not make a difference the car should burp out any air bubbles.
Offline Gunnytron
« Reply #6 on: September 26, 2016, 02:44:03 AM »
No I didn't. Pretty sure there wasn't room for it unfortunately. I have got the hoses r nningbtoeard the front if the car then through the bumper support and then back along the frame rail to the heater.
« Reply #7 on: October 03, 2016, 08:53:39 PM »
flowing bottom up makes the heat work better when there are bubbles though.
« Reply #8 on: October 03, 2016, 10:02:49 PM »
I agree, but the tubes through the firewall are side by side.  Which one goes to the bottom? :scratch:
