Definitely tempted, as far as quality of life items, just want to check on a few things as I'm a bit of a RX7 swap noob.AC is listed as not installed but it looks like most of the parts are there. Is this a install and plumb issue, or are there fabrication and space making to do.2002 wiring harness, are there any major items non functional? I'm guessing no cruise control and/or ABS? How is the top gear, what sort of RPM at 75 mph?How would you say the suspension is, Pittsburgh roads are pretty shitty at times.As a now OBDII car, does the exhaust have cats, would be looking to register in PA, so emissions are something I have to worry about. Also, any CEL's or warning lights that would make inspection difficult.It's a fucking great looking car, and that wrap is
how is the original paint or is that not known?
Quote from: britjh22 on October 13, 2016, 02:25:43 PMDefinitely tempted, as far as quality of life items, just want to check on a few things as I'm a bit of a RX7 swap noob.AC is listed as not installed but it looks like most of the parts are there. Is this a install and plumb issue, or are there fabrication and space making to do.2002 wiring harness, are there any major items non functional? I'm guessing no cruise control and/or ABS? How is the top gear, what sort of RPM at 75 mph?How would you say the suspension is, Pittsburgh roads are pretty shitty at times.As a now OBDII car, does the exhaust have cats, would be looking to register in PA, so emissions are something I have to worry about. Also, any CEL's or warning lights that would make inspection difficult.It's a fucking great looking car, and that wrap is Would you mind sharing the answers to that as well?
