March 15, 2025, 10:39:53 PM
Author Topic: SOLD 1993 R1 Ls1/T56 <75k mi *$15.5k obo  (Read 35686 times)
Offline TheOwl
« on: September 20, 2016, 09:28:51 PM »
Due to unforeseen circumstances i am forced to sell my rx7. I hope to find her a new home through the forum and see her in good hands. I purchased this car from TheProphet36 in January of 2014 with 71k on the clock, and it is currently at 74k. I believe the engine has roughly 400 less miles on it than the chassis. The car was previously built by Joel (Intrnlstorm) and has been meticulously maintained and garage ever since. The car does has two small leaks, power steering from the rack and a very small oil leak from the rear main seal (drop or two at most after parked) was told nothing to worry about, but I want to be as honest as possible.  The diff makes some mild clicking around very tight low speed corners being a clutch type 1.5 way. Otherwise it has micro-polished gears and runs quiet. I did add some Amsoil Slip Lock additive with fluid swap after break-in and it clicks a little less since then. Aside from the mentioned issues the car has always run perfectly, and could definitely be a daily if someone were to choose that route. The car is located in NH.
There was some touch up body work done prior to the vinyl wrap and will need a fresh coat of paint once removed. The paint itself is black and i believe it to be mostly original (New rear bumper at one point). The 3m Matte Grey Aluminum vinyl was professionally installed, looks GREAT and has had the jambs done as well. The car looks amazing and drives even better... it pains me to let her go.
Dyno Tuned (made 344HP/337TQ on a Dynojet Dyno)
steering/Brakes:
HSC FD RX7 Bump Steer Kit (Outer)
Powersteering Boot Kit
SS Brake Lines
EBS Red Stuff all around
Left Rear Wheel Bearing
Rear Axle Nut
Fittings and Lines
Alignment
Interior/electronics:
Leather Seat covers over R1 seats
Momo Steering Wheel
Momo Hub
Double Din Kit
Pioneer AppRadio 3
PVC 6.5" speaker conversion
Polk Audio 6.5" DB561 slim mount
(could use new rear speakers, didn't have much use for the radio)
Hinson Transmission Cover
Wiper Motor
Speedhut Gauges
Replacement Floor & Hatch Mats (red RX7 on black)
Carpet Padding replaced in hatch and bin area's
Weighted/Countersunk Shift Knob
QuietCar (applied on hatch floor and in spare tire area for reduced road noise)
Alarm/Keyless Entry
Engine:
02 LS1
Hinson Cradle
Samberg Radiator
LS6 Intake and Injectors
Coil Packs and Brackets
Oil Dip Stick
Valve Covers
Valve Cover Gaskets
Head Gaskets
ARP Head Studs
Rear Main Seal
Crank Pulley
Hinson Throttle Cable
Stainless Steel Bolt Kit
ARP Assembly Lubricant
ARP Motor Mount Bolts (Block)
ARP Motor Mount Bolts (Frame)
Oil Fill tube
Oil cap
Drivetrain:
Rebuilt T56
Steeda Tri-ax Shifter Handle
LS7 Clutch Kit & Flywheel
Clutch Line
Master Cylinder Mount
Hinson Transmission Mount
Hinson Torque Arm
Hinson Aluminum Driveshaft
ARP LS1/LS2 Flywheel Bolt Kit
ARP LS1/LS2 Pressure Plate Bolt Kit
Tick Performance Remote Clutch SPEEDbleeder Line C5
HSC FD Clutch Master Cylinder
Banjo Bolt, Banjo Fitting, & Washers - 3/8"
GM Pilot Bearing LS1/LS2
Engine Eectrical:
2002 Engine Harness and PCM
Knock Sensor Harness
OBDII Plug
25' 1/0  Gauge Wire
1/0 Gauge Ring Terminal
Spark Plugs and Wires
Ford Taurus Fan pigtail
MAF
Volvo Fan Relay
O2 Sensors
Engine Accessories:
High Torque Starter
New Alternator
Alternator Brackets
Pulleys and Belts
Water Pump
Accessory Belt Tensioner
Powersteering Pump W/Pulley
Powersteering Brackets
Turnone Powersteering Restrictor
Dust/ Inspection Covers
A/C System: (Not Installed)
A/C Bracket
A/C System
A/C Compressor Adapter
A/C Condensor
A/C Dryer
Expansion Valve
Fuel:
Hose Ends -6AN
Braided Fuel Hose -6AN
Corvette FPR and Fittings
Aeromotive 340 Stealth Fuel Pump
Exhaust:
Spec Nur
Custom Y-Pipe
JTR 1-7/8 Headers
ARP Header Bolts
3" Vibrant resonator
Exterior:
3M Matte Grey Aluminum wrap
R1 lip matte black textured finish
rear spoiler shaved (included with sale)
Replacement Light Covers (spares)
HID's (sakebomb HID kit, super bright)
Smoked Front Signals
02+ tail lights including center (great condition)
Tinted Windows
Duraflex type F side skirts (thin diffuser style-not installed)
Suspension & driveline:
Pillow Ball Kit
Poly Bushing Kit (front to rear all replaced, diff, sways, etc)
Tein RA Coilovers
Alignment
Used JDM Control Arms (swapped both arms with used JDM parts from Canada)
Tanabe Front Sway Bar
Rear Wheel Bearings & Axle nuts
Puddymod Diff (built OEM diff, cryo treated, steel reinforced seals and Tomei 1.5 clutch type LSD)
Enkei RP03 Wheels (18x8" fronts/18x9.5" rears) (near MINT)
Hankook Ventus V12 Evo 235/40/18 front, 275/35/18 rear (very good tread left)
At $17k the car will also come with extras including a Noah Custom Car Cover, some misc. seals, oem parts including tails, spoiler, fiberglass interior pieces, etc.
If you have any questions or would like to see high resolution pics feel free to ask, Cory.
« Last Edit: November 19, 2017, 06:40:09 PM by TheOwl »
Offline ncaudio
Re: 1993 R1 Ls1/T56 <75k mi $20k
« Reply #1 on: September 20, 2016, 10:04:56 PM »
Location?
'88 FC LS T56, 94 FD LS T56, '93 FD was LS turbo T56 Ford 8.8 IRS Ablake's old car (project)
Offline the owl
« Reply #2 on: September 20, 2016, 10:22:49 PM »
Trippy screen name....... :scratch:
Good luck with the sale!
1968 Pro-touring Camaro Turbo, LS, Meth and 30psi :drive:
Offline TheOwl
« Reply #3 on: September 20, 2016, 10:25:06 PM »
Sorry, car is located in NH about 40 mins north of Boston.
« Last Edit: September 21, 2016, 02:16:45 AM by TheOwl »
Offline TheOwl
« Reply #4 on: September 20, 2016, 10:49:41 PM »
[attachimg=2][attachimg=3]
« Last Edit: September 21, 2016, 12:51:23 AM by TheOwl »
Offline TheOwl
« Reply #5 on: September 20, 2016, 10:57:32 PM »
[attachimg=1][attachimg=2][attachimg=3][attachimg=4][attachimg=5][attachimg=6]
The low quality pictures do not do this car justice. If you are interested and would like full size images let me know and I can gladly email them. Thank you, Cory.
Offline TheOwl
« Reply #6 on: September 20, 2016, 11:27:11 PM »
Offline bamf3000
« Reply #7 on: September 21, 2016, 10:29:04 AM »
How much did it cost to do the wrap if you dont mind me asking?
Offline TheOwl
« Reply #8 on: September 21, 2016, 03:12:26 PM »
Fortunately I work part time for a 3m certified wrap specialist and was able to do it for much less than the usual cost. I must say the lines on this car were by far the most difficult I've experienced. Lately a job like this fetches around $4,500 or more.
Offline TheOwl
« Reply #9 on: September 21, 2016, 03:13:32 PM »
haha much appreciated!
Offline eraxpres
« Reply #10 on: September 25, 2016, 07:01:41 PM »
beautiful color on the wrap! Were you able to use one solid piece of vinyl for the quarter panel to roof or are there seams, if so where? Thanks
Offline TheOwl
« Reply #11 on: September 26, 2016, 12:32:32 AM »
Thank You! There are a few very well placed seams, roughly at the top and bottom behind the side windows. They flow well with the car and can be spotted in a few pics i posted if you look very closely. there is also a seam at the top of the hatch that is also very clean and almost factory looking. I used knifeless finish line tape for all of the seams to ensure a factory look. Ill try and post pics.
Offline TheOwl
« Reply #12 on: September 26, 2016, 12:48:01 AM »
Offline TheOwl
« Reply #13 on: September 26, 2016, 12:58:32 AM »
[attachimg=4][attachimg=5][attachimg=1][attachimg=2]
« Last Edit: September 26, 2016, 01:04:14 AM by TheOwl »
Offline WutupYo
« Reply #14 on: September 26, 2016, 10:13:39 AM »
Any interest in working out a trade? http://www.norotors.com/index.php?topic=23891.0 Good luck either way. Very pretty car.
