March 18, 2025, 07:53:34 PM
Author Topic: Optimal position for T-56 Magnum shifter.  (Read 3821 times)
Offline CAPTN
« on: September 11, 2016, 06:03:09 PM »
Hi all,
I've been sifting through droves of threads trying to find the optimal position for the shifter on a T-56 magnum. I've seen lots of people post lots of things, but never can tell where exactly the shifter pokes out of the hole once the car is back together. Please keep in mind my car has been apart so freaking long that looking at the shifter protruding from the square metal of the tunnel doesn't really tell me much without the trim around it. I have been planning to to buy the Sikky shifter, but now I see that they offer two options, a 4" and a 7" unit. For that kind of money, I want to order the right one, and my tranny is a while away from being in the car to measure myself. Your advice, knowledge, and commentary is much appreciated!
Offline digital_hoon
Re: Optimal position for T-56 Magnum shifter.
« Reply #1 on: September 12, 2016, 08:47:50 AM »
You need the 4" set-back.
www.C2renders.com  - Digital marketing assets tailored to the automotive aftermarket.
'07 RS4
'93 Montego Blue FD - Mid-operation
Offline CAPTN
« Reply #2 on: September 12, 2016, 09:00:16 AM »
Thank you. Does that allow it to sit perfectly centered in the stock location or is it still offset a bit?
Offline Cryptic
« Reply #3 on: February 01, 2018, 10:25:53 PM »
Bump.... Sikky now offers a 5.5" setback. Any opinions if this would be more ideal?
1995 427 LS3 Burnout Widebody FD
My build thread
2011 Ford F250 CCSB 6.7L
Offline staticx27
« Reply #4 on: February 01, 2018, 10:41:43 PM »
I put this thing in my build, and the shifter came up dead center with a T56 magnum..  And it's like half the price of the Sikky one.
https://www.summitracing.com/parts/awr-shwl20300sr3
Offline Cryptic
« Reply #5 on: February 01, 2018, 10:54:56 PM »
Are you sure you linked the right part?  The image they picture show show a shifter that goes straight up. There is no offset.
My build thread
Offline staticx27
« Reply #6 on: February 01, 2018, 11:29:00 PM »
From the description:
Quote
Shifter, White Lightning, Short Throw, Billet Aluminum, T-56, 3.000 in. Offset, Kit
Yes, I'm sure, I pulled the item number straight from my receipt.
« Reply #7 on: February 05, 2018, 02:29:49 PM »
I sell the White Lightning shifter for proper setback.  That one pictured is the 4 bolt base plate style.  For the T56 Magnum you need the 6 bolt base plate.
One can also modify the stock shifter that comes with it which is written up on norotors.com
« Reply #8 on: February 06, 2018, 08:39:34 AM »
I cut the stock Magnum shifter and had a 3.5"-4" dog leg welded onto it.
It actually feels really nice with just a slightly noticeable vertical movement from the offset. It still feels very tight and not flimsy at all.
BMW DCT Swap, Ronin 8.8" IRS
« Reply #9 on: February 07, 2018, 03:46:15 PM »
I will be doing this and from people that have had the expensive shifters this feels the best.
