Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Search
Recent Posts
Gallery
Search
Stats
Login
Register
This topic
This board
Entire forum
Google
March 18, 2025, 10:36:30 PM
Technical Information
Electronics
Dual relays for redundancy
Add to Reputation:
I agree
I disagree
Comment:
« previous
next »
Print
Pages: [
1
Author
Topic: Dual relays for redundancy (Read 2807 times)
rx7lee
Staged
boost is fun
View Gallery
on:
July 06, 2016, 05:06:42 PM »
I wanting to run dual relays for my fuel pump for redundancy. I want to wire one relay to be triggered by the pcm and the other to be triggered by the key. My question is if I run dual relays with a 10g wire and 10g output off each relay meeting at the pump so I'll have two 10g power wires running to the pump and have the relay from the key witched to power and the r delay from the pcm switched to groud and both relays grounded at the same point will the one that comes on with the key back feed the relay off the pcm or will it be fine?
Last Edit: July 06, 2016, 05:36:34 PM by rx7lee
Logged
93 rx7
radiomike
Supporting Member
Staged
View Gallery
Re: Dual relays for redundancy
Reply #1 on:
July 06, 2016, 05:35:07 PM »
No, it will work fine as there is no connection between the relay coils and the contacts. The only downside is that in a crash you could still have the ignition feed powering the pump even though the engine has stopped.
Logged
rx7lee
Staged
boost is fun
View Gallery
Reply #2 on:
July 06, 2016, 05:38:44 PM »
Crap good point the will be getting the power from the kill switch so when it's off the won't have power but I see what your saying tell the key or kill switch was turned off it would pump fuel. The iusse with letting the pcm run both is we can't get enough prime time on the 411 pcm to build fuel pressure Cuz the pump and reg don't have a check ball
Logged
93 rx7
radiomike
Supporting Member
Staged
View Gallery
Reply #3 on:
July 06, 2016, 06:15:12 PM »
You could still do it with a second relay but use a spring loaded switch not the ignition.
Logged
digitalsolo
Administrator
Top Fuel
View Gallery
Reply #4 on:
July 06, 2016, 06:25:04 PM »
I ran a fuel system with no check valve and a 2 second prime and had no issues? I'd let the PCM control it personally.
Logged
1988 Mazda RX7 - Turbo LS1/T56/ProEFI/8.8/Not Slow... sold.
rx7lee
Staged
boost is fun
View Gallery
Reply #5 on:
July 06, 2016, 06:54:50 PM »
Then there must be iusse with my fuel system I have a 10-15sec prime time and it still takes 3-5 trys to get it to build fuel pressure and start I don't doubt that I have a iusse I just have no idea what to look for or how to fix it
Logged
93 rx7
digitalsolo
Administrator
Top Fuel
View Gallery
Reply #6 on:
July 06, 2016, 07:09:52 PM »
Interesting. What is the setup?
Logged
rx7lee
Staged
boost is fun
View Gallery
Reply #7 on:
July 06, 2016, 09:25:05 PM »
Magnafuel 4303 and magnafuel regulator All an lines.fast fuel rail 80lb deatschwerks injectors -8 tank vent.-12an outlet on the sumped oe tank . No fuel leaks
Logged
93 rx7
digitalsolo
Administrator
Top Fuel
View Gallery
Reply #8 on:
July 07, 2016, 08:30:26 AM »
Hmm. That's pretty similar to BeasTTs and my own setup. Same pump, similar regulator, etc. Both of us ran a 2 second prime and no check valve and it fired at the touch of the key.
If you hot wire the pump to run constantly does it start right up?
Logged
rx7lee
Staged
boost is fun
View Gallery
Reply #9 on:
July 07, 2016, 09:24:27 AM »
Yea that's the weird thing if it's hard wired or once I get fuel pressure it starts right up it starts as fast as my stock Silverado once I get the fuel pressure. Yea I thought you guys ran close to the same fuel setup I'm not sure what the iusse is with my car other then I built it lol id say the guy who tunes it is ok maybe not as good as the guy that tuned your guys stuff but the afr is good once it's running
Logged
93 rx7
Cobranut
Top Fuel
View Gallery
Reply #10 on:
July 07, 2016, 09:56:35 PM »
Is your fuel pump above the level of the tank?
Sounds like it's losing prime, and running the pump dry until it picks up fuel again. Not good for the pump either.
Logged
rx7lee
Staged
boost is fun
View Gallery
Reply #11 on:
July 07, 2016, 10:02:44 PM »
Fuel pump is below the tank and the tank is sumped
Logged
93 rx7
rx7lee
Staged
boost is fun
View Gallery
Reply #12 on:
July 08, 2016, 01:21:57 PM »
Would a 1N5402 diode work to keep the relays from back feeding each other?
Logged
93 rx7
Print
Pages: [
1
« previous
next »
Electronics
Jump to:
=> Electronics
