April 01, 2025, 01:36:24 AM
Author Topic: Kingers Garage  (Read 130705 times)
Re: Kingers Garage - Enjoying the Mississippi built Stroker 7 by Halfspec
« Reply #15 on: June 28, 2016, 09:14:43 PM »
Nice car.
28MPG???  Wow, I've never done much over 14mpg with mine, most tanks are in the 12's and 13's.
My car was tuned for CA 91 octane fuel, and I suspect it might have been tuned on a high ethanol concentration as well, as it runs quite rich on the 0% to 10% we have here.
I plan to pull the drivetrain this winter, and probably go through the motor to freshen it up and check everything out.
I also plan to install a Megasquirt Pro.  I look forward to doing my own tuning, and I suspect there is even more power AND better economy in this motor.
Glad you're enjoying the ride.  :bacon:
Offline XLR8
« Reply #16 on: July 03, 2016, 10:27:10 PM »
Looking good!
I can't remember if Lane cam'd the engine.  What profile?
« Reply #17 on: July 04, 2016, 08:47:54 PM »
Here are the specs. Is this considered mild?
Patriot custom cam .585"/.585" lift, 226/226 duration and 112 lsa
XLR8- what would your detailing recommendation be?  I am looking to have stuff to not scratch the immaculate black coat of paint when I wash and dry it. I see your the detailing expert :). Thanks!!
« Reply #18 on: July 17, 2016, 02:20:12 PM »
Been putting on some more miles and the car is nothing short of amazing. It puts me in a weird happy but scared mode when I drive it!
I got some time to myself today and worked on tracking down the major rattle at idle that was loud and annoying the heck out of me. After combing under the dash I was under the hood and I noticed some wear in the POR15 coating in the engine bay behind the brake lines.
I stuffed a rag in between and sure enough the noise is gone!  Pulled the rag and it came back. So I got some rubber insulation and placed it on the lines and the car is noise free at idle...yay!
I was looking at the exhaust wanting to quiet it some and I noticed my JTR headers hitting the samberg subframe. Is this common?  Any fixes?  These are 1-7/8" primaries.
I did have the MIL come on so I ordered a ELM327 and looking for apps now to scan it with.  I do have a appointment on the 11th to go speed density if he can't get the MAF dialed in. It's close but I get some bucking and have some minor issues with the AC on wanting to stall while coasting. It's cool the tuner is CJs in St. Paul and seems very smart on this. Plus I like his process I bring it in the morning and he works with it all day than lets it sit over night and works the cold start in the morning if needed. I said I want it OEM like control cold or hot and he said that is the only way he does them :)  He comes highly recommended by many swap guys up here and knew the problems with a MAF on the OTR set up like the samberg intake.
Lastly programmed my Gentex auto dimming mirror for my garage and finally can ditch the garage door opener.
So the car is rattle free and I hope the tuner makes her run as smooth as silk.  All in all a good day.
« Reply #19 on: July 18, 2016, 12:01:01 PM »
Anyone know how to refurbish the AC button? Any overlay kits available?
Offline halfspec
« Reply #20 on: July 18, 2016, 12:23:07 PM »
Mazda doesn't sell the button plastic or the AC switch separate from the HVAC panel and they don't sell HVAC panels anymore so there are no sources for buying one new.
No known aftermarket replacements. I took full advantage of known aftermarket parts when rebuilding the panel.
That leaves you with the used market or trying to commission someone like Broadfield or someone else that's an artist with refurbishing / recoating plastic parts and/or silkscreening.
I will warn you. The HVAC panel should absolutely be treated as gold. Like I mentioned above. There are no sources for new panels, so if you break it you're going to have to buy used and I can assure you, yours is better than 90% of what's out there and that other 10% will be high $$$. I only say that because like all FD plastics it's fragile and one wrong move during removal can snap tabs and plastic bosses like balsa wood. I have no fear when it comes to dismantling anything but when it comes to that panel, I check myself and make sure its necessary then proceed with extreme caution :D
No idea about the JTRs. I knew the install was close but didn't realize they were making contact with the subframe.
Lane
« Reply #21 on: July 18, 2016, 02:19:14 PM »
Sounds like a perfect sharpie opportunity LOL
« Reply #22 on: July 28, 2016, 11:01:30 AM »
Not a lot to update but I have had a few issues that I got resolved and will post them here if nothing else for documentation purposes for the car.
#1 rattles are all GONE.  It turned out it was the brake lines and Halfspec kindly sent me a Box-o-parts with a bunch of random bolts, clips, etc from disassembly and even new OEM fasteners in there.  I was epxcting a pile of stuff and of course it all came in neatly labeled baggies!  Thank you Lane, I envy your organization skills.  Anyway I have found a host of mostly non-important parts that were missing are now installed on the car.  Included in this was 2 brand new brake line holders with a rubber isolator on both the firewall and the lines themselves.  This stopped most of the rattling.  The temporarily trunk fix is working mint and there is nothing annoying there.  The cam is considered mild but it has a nice shake at idle letting passengers know don't F with me (the car talking).  Now it can sit there and chug with only the glorious sounds of the 6.2L.  Little things like this make me happy  :)
#2  A issue that came with the car since the day it showed up on the trailer - Click click start that is so common on FD's.  Lane has been most helpful here helping me understand the wiring.  Basically he eliminated the stock security relay and ran the starter cut though the Viper alarm, everything else is stock.  Well after thinking it was maybe a loose starter wire as it would get better and not occur when warm, I found the issue to be the clutch interlock switch.  Its funny because when I ohm it out, it works perfect with the pedal showing open until you press the clutch, than I get random Ohms on each clutch press, 5,6,7 ohms.  I read on the club it should be <5 ohms.  I bypassed it with a jumper wire on the harness side and its been flawless since.  Eventually I will replace that switch but its buried up there!
#3 Sunroof switch actually broke apart inside (see post in electronics) Wickedrx7 was nice enough to send me a new switch and when it gets here I will have a working roof again.  Easy fix for sure and helped me learn about some of the fragility of a FD!  I like these little projects that I can identify and sometimes fix in my free time after the kids go to bed in the evening :)
One problem I still haven't resolved is of all things the gas cap.  Lane has a sealed gas tank from the PO and used a vented cap and actually modified to flow both ways with no valve.  I was doing some 'spirited' :)  driving after just filling up the tank and noticed gas was running right out of it on a hard right hand turn!  I called Stant to see what they recommend and they said they have nothing?! WTF?  I will figure something out.
Thanks!
Offline rajeevx7
  • Pre-Staging
  • FD owner since 1998. V8FD owner since 2010
« Reply #23 on: July 30, 2016, 01:02:32 PM »
Really sweet tail lights! Not many people around are willing to put $1k into tail lights on these ancient cars:-)
'93 BB R1 Ls6 - 2001-2023
'93 MB Touring 13b-Rew - 1998-2001
« Reply #24 on: August 03, 2016, 09:38:32 AM »
Tell me about it!  It was a big gulp to pay that bill!  They really are worth it though, people think its a exotic car and the taillights no longer give its 90's vintage away.  They are one of my favorite parts of the car, I freq roll around with the parking lights on during the day just to show them off LOL.
Offline radiomike
« Reply #25 on: August 03, 2016, 06:02:54 PM »
Coming back to the bucking, does this happen at cruise on very light throttle openings?  In our case using an LS3 with the Samberg MAF elbow we initially used a honeycomb MAF guide which improved things by 75% or so but it was still not perfect.  Reading the GM crate engine installation notes we noted that the MAF should be fitted centrally in a 10" length of 4" diameter straight tube; that was never going to happen due to space restrictions but we tried a slightly shorter straight tube and used a tighter silicone bend onto the filter, this time without the honeycomb. The hood still closes fine and the bucking is all but gone.  Combined with a tune I think it would be possible to totally eliminate the bucking with a standard cam, the larger cam in yours may be slightly more difficult.
« Reply #26 on: August 03, 2016, 10:40:38 PM »
I'm telling ya, one you go SD, you'll never miss MAF.  ;)
« Reply #27 on: August 04, 2016, 08:48:57 AM »
That's my plan when I switch to MegaSquirt Pro.    8)
« Reply #28 on: August 04, 2016, 11:45:30 AM »
Yes that is the worst, under even moderate throttle no bucking is present.
Aug 11th I'm leaving the car for 2 days for a comprehensive tune with a highly regarded tuner in St. Paul.  He has tuned OTR (over the radiator) intakes on swapped 7's and knows the MAF table has to be 100% perfect.  He was quick to point out, if its not making progress he will disable the MAF, leave it in place, just to use the thermoresistor (LS7 MAF), and run full SD off the tables.  He keeps the car overnight to evaluate cold start the next day.
I'm excited because if we can smooth it out, it will be the sweetest DD!  The car is so smooth and rides so nice once the bucking and my J pipe drone eliminator gets installed on the exhaust and it will be my dream cruiser with the power to scare the wee out of you at any given time!
« Reply #29 on: August 04, 2016, 12:44:26 PM »
Did I miss the discussion on the J pipe drone eliminator! More info please.
