March 05, 2025, 08:18:03 PM
Author Topic: how to 2JZ an FC  (Read 80973 times)
Re: how to 2JZ an FC
« Reply #135 on: February 02, 2018, 09:07:06 AM »
Carnage!  Good thing 2 strokes are relatively simple to rebuild.  421 should be a nice increase haha.  FC is looking good too
« Reply #136 on: February 02, 2018, 04:22:30 PM »
I bought the RZ350 from a friend back in the late 80's, for $750.  :D
I replaced the clutch, put on a set of chambers and opened up the airbox, and eventually re-ringed it and polished the ports.
I probably have a little over $1,500 in it now.  It's still in solid condition, but would need some work to get it running again after sitting for so long.
Here's a few pics I took a couple years ago.  Note the tag expiration, it's been a while. LOL
« Last Edit: March 28, 2018, 05:34:08 PM by Cobranut »
« Reply #137 on: February 03, 2018, 06:53:20 AM »
David that thing is immaculate, its worth some serious money now
Offline danny33
« Reply #138 on: February 03, 2018, 05:35:19 PM »
AWESOME. looks to be in great condition, love the color scheme as well!
Offline danny33
« Reply #139 on: February 26, 2018, 08:55:46 PM »
she is up and running. Had a fun hour of diagnosing a crank no start which ended up being some voltage drop to the injectors, they were not firing on 8V LOL- go figure. got a few things to iron out and then going to order my driveshaft and plumb the clutch before going for a drive!!
https://youtu.be/CmKCvUvkMnw
« Reply #140 on: February 27, 2018, 10:16:38 AM »
Sounds good!
Offline danny33
« Reply #141 on: March 28, 2018, 12:54:49 PM »
Update. added 2 relays for all my switched 12V stuff and was able to add 2 more fuses to the underhood mazda fuse box to power everything so it is still clean. The Fab shop nicked my radiator when drilling holes for the rivnuts and it took them 2 weeks to weld up the radiator. Currently have a driveshaft installed, clutch master plumbed and bled, and cooling system back together with no leaks. Had her running last night for a little but it idles at 2K currently due to the previous voltage drop issues (8V) to the IAC/ VVTI ( we added duty cycle to IAC to meet idle target ). We are going to spend some time this week on a webchat and clean up the idle and make some other adjustments before we start road tuning the car. Once it stops raining in dallas i will probably drive it around my sub division. Also need to mount tires and get it registered. Fingers crossed i dont run into anything major during initial road testing.
« Reply #142 on: March 28, 2018, 02:59:56 PM »
Congrats!!!    This is such a well done swap.   Very impressive work.
Offline danny33
« Reply #143 on: March 29, 2018, 02:33:27 PM »
Thank you sir, means a lot coming from you. now finish up that mustang.
Offline danny33
« Reply #144 on: March 30, 2018, 10:01:05 PM »
Currently have the car running smoothly and ready to drive. We did some adjustments to the tune earlier today and noticed that my TPS was reading backwards. After verifying the wiring was correct a few times, i ran the part number on the sensor and found out it is a 2JZ GE sensor and that they actually rotate the opposite way (mounted on the opposite side of intake). Currently hunting for a GTE TPS locally so i can hit the road this weekend!!!!
Offline danny33
« Reply #145 on: April 06, 2018, 09:22:41 PM »
I wanted to update this with some info on the last pieces for anyone referencing this thread. As stated earlier, after smoothing out some cold starts and idle tables on the tune, we noticed that my throttle % would read negative when snapping the throttle. Turns out the used manifold i bought to delete the aristo DBW throttle had a 2JZ GE TPS sensor installed which rotates backwards. I have a new sensor on order but it wont be here until next week.
For a throttle cable, i bought a $22 FD RX7 cable from summit and cut the throttle end off and then cut the cable to length. After i did this, i crimped the threaded housing end back onto the cable and then used a set crew type cable end lug. This worked well as the firewall clip and throttle pedal clip were all the same as the OEM cable.
For a driveshaft, i had a custom one made by a local shop - fort worth gear and axle. total distance between output shaft and pinion flange was 34-7/16". Most driveline shops order slip yokes/ flanges from powertrain industries and for a CD009 you will need a 3503-323 slip yoke and the turbo II pinion flange 2602-41. For reference, i am using a TII housing with a Kaaz 1.5way LSD. An 8.8 kit with gearing to match the CD009 is on the list. I already have a complete 8.8 LSD waiting for me to pick up.
Clutch setup is an ACT sprung 6 puck 350Z clutch on the collins kit with flywheel. I used the 350Z slave cylinder with the 350Z OEM sized master cylinder from Wilwood in 5/8. Stu kelley firewall adapter and trimmed Mazda clutch pushrod. I had a custom clutch line made by chasebays @ 33" length.
I did have some issues with voltage drop from the Mazda chassis wiring i tapped into in the engine bay. I ended up adding 2 additional fuses to the mazda underhood fuse box using terminals i harvested from other connectors. I then ran 2 relays underhood to supply power to the VVTI, IAC, and injectors. The other relay feeds the cooling fans to reduce any voltage drop from the relaybox mounted in my passenger cubby.
I will be mounting tires soon and will be running Falken Azenis RT615K+ in 225/40/18 in the front and Nitto NT01s in the rear @ 265/40/18. Before the car is truly roadworthy i need to do front control arm bushings, order the Hinson sway bar spacers, and replace the front wheel bearings using the mazdatrix stuff.
I also cleaned up the lines for my breather setup and routed some things differently.
I have a chasebays coolant overflow on order so ignore the line running over the rad support. I will likely mount the overflow under the air filter.
« Reply #146 on: April 06, 2018, 09:53:34 PM »
Looks good!
Offline danny33
« Reply #147 on: April 07, 2018, 04:54:03 PM »
I just updated the beginning of this thread to dump tons of pics that were lost through photobucket for anyone reading through.
« Last Edit: April 07, 2018, 05:08:43 PM by danny33 »
Offline danny33
« Reply #148 on: April 12, 2018, 10:19:58 PM »
Ordered my TPS from drift motion like 11 days ago and it finally showed up on Monday. I installed it today, adjusted it and then went for a 25 minute drive throughout my subdivision. Initial thoughts are- definitely need to get power steering ASAP, 1.5way locked diff from KAAZ is noisy!!. Other than that, i am going to play around with clutch adjustment and rebleed it again using Blakes method. The car drove smooth and revved up clean. Monitoring my datalogs, i never surpassed 183* coolant temp or dropped below 43PSI of fuel pressure. I will be trying to get the car registered tomorrow and mount tires before road tuning the car further. Took some shitty videos on my phone which i posted to youtube and linked below.
PS- Does anyone have any input on fuel tank venting when doing a swap? i removed all my vent lines to the engine but left everything else. I suspected that it might not be venting and opened the cap after driving today and it released or pulled in a lot of air once i cracked the cap. Does anyone run a vented cap, and if so have a part #?? appreciate any feedback.
https://youtu.be/hrcVSHQBnqk
Offline danny33
« Reply #149 on: April 21, 2018, 12:07:18 AM »
Got my tires mounted today and the ride height set. Was able to put about 45 miles on the car since i got plates this week as well. So far so good. Biggest issue i am having is an oil drip from the oil cooler thermostat bolt but have an order from mazdatrix coming tomorrow which includes new front wheel bearings and a new crush washer for the oil cooler. Also have some KAAZ LSD fluid that should be here tomorrow to hopefully help quiet down my diff. I am suspecting the kid who owned it before didnt use KAAZ fluid in it which causes clunking on slow turns. Heres some pics from a photoshoot i took while on a beer run  :cheers:
Tires are 225/40/R18 and 265/40/R18
Also got my hood vent in. Not very happy with the quality on this, going to need some work before its acceptable. I will be trimming the rear a lot and probably mounting it lower than it is currently.
