The CAD study was my pause point as the Cruiser moved 2,500 miles—plus an ocean—with cardboard taped to the firewall.
Once we were settled in, I started picking away at the projects I could get too without fully unpacking the rig. It still had doors, hatch, and a bunch of boxes stored inside. That’s why I went after the rear seat first, it was one of the easiest areas to get to and working from the ends on the big interfaces seemed like a good place to start.
That said, the firewall is about the most complicated interface I have left to play with. Headers, pedals, steering, remote oil filter, feet. It all has to be happy ergonomically and play nice with one another. Ironically, I think the steering gives me a bit of a free pass since I can put the control valve under the dash and run lines where I want them (no steering column with full hydro).
Anyways, fam was out of town and had a friend who wanted to hang so I recruited a helper for wrenching (we dialed in his steering on the JK, so I got to return favor a bit). Decided it was time to launch into the firewall.
Here’s how it sat after finally unstrapping the 2x hoods.
When I did primer on most places, I also seam sealed and shot the shock towers black, in what I think will be my color for all the tube work. I’m using Rustoleum Engine Enamel Low Gloss Black.
https://www.homedepot.com/p/Rust-Oleum-Automotive-12-oz-Low-Gloss-Black-Engine-Enamel-Spray-Paint-6-Pack-248938/202436448Good stuff, oil and chip resistant, holds up well under UV, easy to touch up given the low gloss. Thanks to 65imp for turning me onto the stuff.
The idea in pre painting these areas is that it will simplify painting around the shocks in the future… It also protect voids and crevasses that will be hard to sand/scuff up later. I’m sure I’m not the only one who looks at a stupid-far-from-finished rig and contemplates paint colors (current lead candidate is metallic orange w/ a silver roof and black tube work/fenders, but I also get excited about aquamarine on occasion).
Part of what makes the template work—in theory anyways—is that it tips the pedals a bit (mounting surface isn’t vertical).
It looks OK, so I convert to steel. I’m using 0.050” because it’s what I have handy and seems reasonable. I will plan to reinforce pedals to help stiffen the firewall vs. just tin canning some flat pieces.
This is the kinda work where my mag brake excels. One piece FTW!
By the way, my friend John plays a mean didgeridoo and found a chunk of ABS on my wall that worked pretty well.
First snag… Pedals need more vertical real estate. Since I hadn’t cut out the firewall to verify the inside fitment I missed this. I had to cut the top seams and fold my steel work back open. I suppose I could cut the pedals but I’m trying to keep as much of that stock as I can. If I’m lucky, I’m hoping I can use an S2k throttle cable grommet.
Here it is with firewall cut away and the new piece mocked up behind. I did left a flange I can bend over to help welding up the seams (with thanks to Project Binky for that build tip).
But now I have a real problem. The overall vertical clearance is damn tight… Putting the pedals where I want them to be I run a real risk of the booster or master cylinder crashing into the hood. Remember that thing about the pedals needing to tip for fore/aft clearance? That makes my MC/booster combo point somewhat uphill. That makes it a harder 3D problem than my simple header lego mockup.
Measure all three of my other cars, the throttle tends to be about 4.5” off the floor, brake more like 6”. As shown I’m only at 4” for throttle and not quite 5” for the brake. I don’t think I have an inch left of room to the hood.
Decide not to be a wuss and even though it’s late and I’m tired, I bit the bullet and unload everything from inside the rig. I have to try this and see what it feels like and my brain is too wired up to sleep not knowing. Get the front seat mocked in and try it out. Sure enough, the pedals feel low. You can tell through the soles of your feet. Dammit… Joys of custom vehicles I guess.
I certainly want to get the MC/booster as high as I can, so that’ll take some careful mockups and I need to get the booster mounted all the way—which I can’t do without my firewall fortifications since I need thickness for the mounting to be correct. I also need to track down an MC reservoir as they intentionally break those at the junkyard. I can’t remember if I keep the broken one or not, gotta dig.
I can cut and relocate the pedals on their respective swing arms but I’m a little worried about having enough brake gain and/or an overly sensitive throttle pedal. The brake calipers are huge and were intended for use with a hydroboost, which I can’t do because of my fully hydro steering. Every story I’ve read about daisy chaining hydro steering and brakes off a common pump ends badly and I’m not ready to try to package a second PS pump… If I think this is bad, I’m DEFINITELY not stoked on working that one out.
I could run a smaller diameter booster (maybe) but again, I need the brake system gain because of the huge tires. I can’t move the floorboards down and still have space for the exhaust to run inside my triangular space frame boat sides thingies. Oh and if I get this wrong, I won’t know until I’m way way down the road.
Suggestions? Worth hooking up the full brake system so I can try the pedal? I kinda don’t think it’ll be representative enough without vacuum and I have a long way to go before this thing can move on its own to check. Anyone know brake system experts in the industry I could reach out to? I’d gladly pay a few hundo for a consult at this point.
In the meantime, I need to design myself in as much flexibility as I can. If that means I have to build the entire firewall extension but only tack it in—to able to move the whole piece around and allow different boosters and what not—that might be what I have to do.
