Looking to possibly trade my one of a kind FC RX7 for LS FD, C6 Vette or something else. Took 2 years to build and finally almost completed. The car is located in Los Angeles, CA. There has been so many things done to this car not sure where to start. Still some little things on the car that needs to be addressed like wiring the boost controller, wiring headlights/ taillights, calibrating the racepak, bleeding the brakes, setting the idle, and wiring the fans. The car starts up no problem and recently went on the dyno. Made 344WHP on 91 octane with 8LBs (wastegate was not working correctly since not wired to boost controller). The car is mainly a track car but can be street driven as it does have a Cali title. It's been a long journey building this thing but the things I want have changed and it's time to move onto something else. Email me at yufengcorse gmail dot com with what you got and I'll get back to you even if it's a no. I know what my cars worth so please don't offer me anything that does not make sense.
Car:
1987 RX7 SE (comes with spare car which is 1991 GXL bone stock) both clean Cali title
Engine:
1998 toyota supra 2JV VVTI (internal good for 800hp and bottom end for over 1000)
Full race twin scroll EFR manifold
Borgwarner 8374 EFR turbo 1.05 AR EWG (900hp+)
Turbo smart 44MM waste gates X2 (17lb springs)
Tech 2 motorsports swap kit
Tech 2 motorsports intercooler and pipping
Tech 2 motorsports radiator
Tech 2 motorsports power steering line
Flex-A-Lite dual 12 inch fans
AEM V2 EMS computer
Chasebays custom milspec harness
Tomei adjustable cam gear
Gates racing timing belt
Lightweight pulleys
Drift motion fuel rail
Bosch 1000CC modified high impedance injectors (E85 ready)
Walboro 450 fuel pump
Aeromotive fuel regulator
Drift motion serpentine belt
Drivetrain:
6 speed V161 Getrag transmission (can hold up to 1400HP if shifted properly)
NEW* Clutchmasters FX850 (1000hp+ EASY)
Tech 2 motorsports V16* mount
Tech 2 motorsports driveshaft (good for 800hp+ but not sure about launches)
S4 turbo 2 pumpkin (recommend rem coating pinion gear or reinforcing if launching)
NEW* OS Giken super lock diff (1200hp+)
Driveshaft shop pro half shafts (good for launches and 2000hp+)
Atkins rotary bearing seals
5 lug conversion
Brakes:
Turbo 2 front and rear
Stoptech slotted rotors
Stoptech pads
Lucky duck auto brake lines
Era-1 hydraulic handbrake with wildwood 3/8 master cylinder
Suspension:
PBM Max pro coilovers 10KG/8KG springs
NEW* GSP sway bars
Chassis:
PBM FC trailing arm front bushing spherical conversion
PBM FC sub frame riser
PBM FC solid diff riser
PBM FC solid diff forward bushing mount
PBM FC toe eliminator bushing
PBM FC trailing arm upper bushing
PBM FC super angle kit
PBM FC toe adjustable rear lateral rods
PBM FC subframe camber arm
PBM FC trailing arm camber links
Interior:
Sparco Corsa
Sparco Pro 2000
NEW* Sparco 6pt hans driver harness
NEW* Sparco 6pt passenger harness
NEW* Cusco 13pt bolt in roll cage (comes with new autopower roll bar)
Racepak IQ3 dash (pulls direct into wiring harness)
Momo steering wheel hub
NEW* Momo 350MM steering wheel
Exterior:
BN sports replica kit
BCL rear wing
JTP front 50mm and rear 50mm over fenders with carbon liners
4x red Volk TE37SL 18x10.5 ET 15 (new advan neova)
4x pink Rays Gramlight 18x9.5 and 18x10.5 ET15 (new toyo R888)
NEW* 2x pressed graphite Volk TE37SL 18x9.5 ET22
Raybrig headlights
Custom hood to clear engine and turbo
Locking Aerocatch hood pins with stock latch
Black with red pearl paint job by west jones auto claims
2JZ FC plate
