March 17, 2025, 02:38:08 AM
Author Topic: Cam selection for twin turbo LQ9  (Read 5027 times)
Offline zeeshan
« on: May 30, 2015, 01:00:45 PM »
I am thinking of replacing the stock cam with something different to decrease the amount of overlap between intake and exhaust. This way I don't have to run as much boost to make the power I am trying to aim for.
A couple things I want:
1. I want to use beehive springs (Cam valve lift should be max .600")
2. I want to prolong the life of valve train so I don't want aggressive lobe profiles.
3. MORE POWER!!!
I searched and see people recommending LS6 cam (they arent specific on if its the 2001 or 2002 they're talking about. there is a lift difference between the two and some duration difference). This recommendation doesn't make sense to me.
LQ9 Cam 207/196 int/exh 116 LSA 0.479" / 0.467" int/exh lift -> overlap = -30.5
2001 LS6 Cam 207/217 int/exh @ 0.05" duration 116 LSA 0.525" / 0.525" int/exh lift -> overlap = -20
2002 LS6 Cam 204/218 int/exh @ 0.05" duration 117 LSA 0.551" / 0.547" int/exh lift -> overlap = -23
GMPP Hot cam 218/227 int/exh @ 0.05" duration 112 LSA 0.525" / 0.525" int/exh lift -> overlap = -1.5
Tick Performance Turbo Stage 1 Cam 227/227 int/exh @ 0.05" duration 114 LSA 0.62x" / 0.59x" int/exh lift -> overlap = -1
It seems like both the LS6 cams have a crap load of overlap, while both the GMPP hot cam and tick performance stage 1 cam have significantly less overlap. This is why I don't understand why people recommend the LS6 cam.
Is there a cam like the tick performance turbo stage 1 cam that has like <.6" lift? I really want to stick to beehives.
Re: Cam selection for twin turbo LQ9
« Reply #1 on: May 30, 2015, 01:25:33 PM »
Need to know the rest of the combo. The can is the last piece
« Reply #2 on: May 30, 2015, 01:27:08 PM »
You can look at the comp matter catalog and pick whatever lobes you want. I speced my own and I picked the tamest lobes they had
Offline zeeshan
« Reply #3 on: May 30, 2015, 01:33:58 PM »
-Twin t3/t04e-50 trims with .82a/r turbine housings
-Completely Stock LQ9 (317 heads)
-LS1 Intake manifold
-T56 Transmission
« Reply #4 on: May 30, 2015, 06:06:09 PM »
What turbine?
Offline zeeshan
« Reply #5 on: May 30, 2015, 09:22:57 PM »
 http://www.thedodgegarage.com/turbo/adv_comp_map_50.gif
^ compressor map for turbo
65mm exducer for the turbine wheel
Offline BeasTT
  • Twinz for teh winz
« Reply #6 on: May 31, 2015, 01:47:31 AM »
02+ LS6 or an LPE GT7
Nick Shultz
1993 Rx-7
« Reply #7 on: May 31, 2015, 10:19:38 PM »
The discontinued the GT7, as the LS9 cam is almost identical.
Offline awd-rwd racer
« Reply #8 on: May 31, 2015, 11:02:01 PM »
im running a tick performance 226/235 .605"/.610" 115+2 camshaft in my setup.
i called and spoke to martin and told him what i was doing and this is a custom grind they had for me.
Offline BeasTT
« Reply #9 on: June 01, 2015, 12:27:20 AM »
Brain fart. I have the last GT7 ever made in my Avalanche. You'd think I would have remembered that.
Nick Shultz
1993 Rx-7
« Reply #10 on: June 01, 2015, 04:17:45 AM »
If you need an RXT clutch to hold the power...... I sell them :)
you can even reuse your LS1 flywheel if you wanted.
Offline zeeshan
« Reply #11 on: June 01, 2015, 02:05:28 PM »
I've been reading about turbo cam design and there is quite a bit involved. I think i'm going to keep my cam stock right now, get a baseline dyno with the turbos and then change cammotion cam. The cammotion cam I am looking at is: http://store.cammotion.com/turbo-stage- (220/216 i/e, 114LSA, .578/.561 i/e, -10 overlap). This is couple notches  above the ls6 cam i'd think just based by the specs.
By having a baseline to compare with, I want to know for sure how much of a difference the cam makes on my engine.
« Reply #12 on: June 01, 2015, 02:08:38 PM »
A reverse split makes no sense at all to me.
Offline zeeshan
« Reply #13 on: June 01, 2015, 03:08:21 PM »
It doesn't make sense to me either, but that is what cammotion offers for their turbo grinds. I think the idea is to reduce back pressure, but these might be designed for really big turbos. Now thinking about it, with smaller twins, back pressure isn't as big of a deal so maybe I do need a cam that is designed for N/A.
Like this one:
http://store.cammotion.com/57-ls1-346ci-101-compression-3  (222/226 i/e, 114LSA, .544/.535 i/e, -4 overlap)
« Reply #14 on: June 01, 2015, 08:59:17 PM »
My Thunder Racing CheaTR cam worked well in my car (214/230 .601/.578 117 LSA)
My theory was to pull the duration toward the exhaust to crutch the smaller turbo and decrease spool time.   Car made excellent power and was a ton of fun to drive.   If you have plenty of turbine flow, you probably don't need as much exhaust bias though.
