March 28, 2025, 08:13:05 PM
Author Topic: Headlights, tails, more  (Read 1777 times)
Offline Desertpunk
« on: March 13, 2015, 05:43:58 PM »
I tried to search for anything on this buy I did not see anything. I am getting ready to swap my FC and i cant figure out about Headlight, Tails, turn signals and ect. My buddy told me to use the stuff that is already wired in but upon removing engine wiring I found it all connects into the ECU. Can some one tell me exactly what I need and don't need? not going to have heat or ac or anything like that I just want to know about the basic stuff.
-Ian
Offline Dr1ft1ng0wns
Re: Headlights, tails, more
« Reply #1 on: March 14, 2015, 09:54:26 PM »
None of the lights run through the ecu. All the lights are in the harness on the driver side of the engine bay. My car has all of the ecu wiring removed along with the ecu itself and all the lights work. All you should have to do to get the lights working is put power into the fusebox on the driver side strut tower.
83 K5 Blazer on 37's
01 Civic DD
Offline Desertpunk
« Reply #2 on: March 15, 2015, 09:43:57 PM »
thanks so much for the input! That helped so much in figuring out my electrical problem.
