March 31, 2025, 04:12:59 PM
Author Topic: abs used to run speedometer  (Read 4174 times)
Offline rx7lee
« on: February 20, 2015, 10:43:21 PM »
Can one of the front wheel abs sensors be used with a Dakota sgi-5 box to run the speedometer on a fd?
:drive: 93 rx7
Offline Skeltic
Re: abs used to run speedometer
« Reply #1 on: February 21, 2015, 04:22:13 PM »
That sounds like something that would work
Offline rx7lee
« Reply #2 on: February 21, 2015, 05:52:47 PM »
I'm thinking it would I just need to figure out how to find out how many pulse  pre mile the stock abs sensors are
:drive: 93 rx7
Offline gc3
« Reply #3 on: February 21, 2015, 07:21:04 PM »
count the tone ring and multiply it by tire circumference speed
Offline mdickw
« Reply #4 on: February 23, 2015, 02:45:50 PM »
Looks like the ABS wheels are 44 teeth (from looking at pics). That would work out to about 34k ppm for a stockish size. According to the manual, the SGI-5 should be able to accommodate that, though it does explicitly say not to connect to ABS sensors. I think that's more for liability than technical reasons. If you're still running ABS, though, it would be a bad idea to use one of the wheel speed sensors. The SGI-5 might sink too much current (but probably not), distorting the signal from the sensor. The additional wiring to get the SGI-5 onto the circuit could also introduce a lot of noise. That said, it would probably work fine.
Why do you want to use the wheel speed sensors? Too much extra mileage from spinning your tires?
Offline rx7lee
« Reply #5 on: February 24, 2015, 10:11:15 AM »
Thanks guys. I want to use the abs sensor cuz I don't run abs and my transmission don't have a speed sensor
:drive: 93 rx7
Offline mdickw
« Reply #6 on: February 24, 2015, 10:31:32 AM »
Cool, let us know if it works..
Offline Jordan Innovations
    • Jordan Innovations
« Reply #7 on: February 24, 2015, 02:12:30 PM »
Generally the wheelspeed sensors aren't great places to pull speed from - the output is very low voltage, very fast, has to travel a hellishly long distance in the car, usually along with high-amp wires (battery, fuel pump, etc), and needs some filtering to be accurate or consistent.  The Dakota Digital boxes should have settings to bring the speed down enough, but I don't know if the output will be what you're used to seeing on a speedo.
My recommendation would be a mag sensor that reads the driveshaft nuts where they enter the diff - high-res, better speed (~16 pulses per wheel rev, vs 40), and less noise.
Offline rx7lee
« Reply #8 on: February 24, 2015, 03:24:05 PM »
I was trying to keep from having to do that as it would have me trying to fab some kind of a bracket to hold the sensor but I think that is the best way to do it . I was hoping if I used a shielded wire from the and sensor to the box and used the sensor ground on the box that it would help with noise
:drive: 93 rx7
Offline stbrn19
« Reply #9 on: March 16, 2015, 02:52:18 AM »
Any progress with this project?
