the patented wood under the gas pedal would work.
Serious though, you want as much power in your torque curve as possible, so something to cut power at the top end would be ideal, I think there is a way in the ls ecu that you can set max torque, so I would look into that, I know that you can program it to throw a code and go into limp mode if you go over the set torque number, I am unsure weather you can change it from throwing a code to just cutting spark, like the rev limiter.
Good luck
