April 01, 2025, 01:26:13 AM
Author Topic: Enough CFM?  (Read 7147 times)
Offline cyris426
Enough CFM?
« on: February 01, 2015, 08:21:12 PM »
Hey guys,
I have a 1984 GSL-SE that i put a ford 302 into. I am looking at cooling it and am curious what CFM fan is needed. The rad core is 11inch by 23inch and is a 3 core. I am looking at a fan that will fit on the core (11x23) and can pull enough air. I plan on building a shroud also. It is a stock 302, prolly makes 250 or so torque and 150 or so horsepower. There is 2.7 or so inch's of clearance in between the electric water pump and the rad which limits the size of fan.
I am looking at this fan: http://www.jegs.com/i/SPAL/063/30100364/10002/-1?parentProductId=2861424
Is this going to be enough CFM with a shroud? Or will i fall short in hotter temps? Summer gets about 30 or so Cecilius here.
Thanks
Re: Enough CFM?
« Reply #1 on: February 01, 2015, 09:05:21 PM »
Static pressure is more important than CFM for a cooling fan.
Re: Enough CFM?
« Reply #2 on: February 01, 2015, 09:08:24 PM »
Look at the amp draw of a fan if you want an idea of its capacity. Don't believe crap you read on flow rates
Re: Enough CFM?
« Reply #3 on: February 01, 2015, 09:38:09 PM »
^Agreed. Some companies give a graph of CFM amperage and pressure.
Offline cyris426
Re: Enough CFM?
« Reply #4 on: February 01, 2015, 10:22:33 PM »
They say that fan is 7 AMPS.
Re: Enough CFM?
« Reply #5 on: February 01, 2015, 11:32:38 PM »
A Ford Taurus Fan supposedly pulls 4000 cfm.  I have a 60amp relay on mine.
I would ping the other V8 FB guys to see what they run before buying anything.  That is a small dimensional radiator... but 3 core is good!
Not many 10" fans that fit your core are going to pull much at all.
Offline cyris426
Re: Enough CFM?
« Reply #6 on: February 02, 2015, 09:53:50 AM »
How do i ping them? What does that mean?
Thanks
Re: Enough CFM?
« Reply #7 on: February 02, 2015, 09:59:22 AM »
7 amp isn't gonna do shit.   Find something else. An OEM app fan is usually your best bet
Offline cyris426
Re: Enough CFM?
« Reply #8 on: February 03, 2015, 12:25:05 AM »
That's as good as i can get for that low profile. There is only 2.6 or 2.7 or so of clearance in between the rad and the water pump. Any other ideas?
Offline cyris426
Re: Enough CFM?
« Reply #9 on: February 03, 2015, 12:34:09 AM »
http://www.etrailer.com/Radiator-Fans/Derale/D16112.html
What about this one? It is rated at 14 amps and is low enough profile to fit
Offline Bowtie7
Re: Enough CFM?
« Reply #10 on: February 03, 2015, 10:01:04 AM »
Ive been using fbody fans forever and had great success with them. I run a 30A relay on each fan. FC's will not overheat in stop and go summer traffic with a/c on. Temp never above 210.
I do love what I do!
Re: Enough CFM?
« Reply #11 on: February 03, 2015, 10:24:50 AM »
What they say about electric fans not using engine power is false. It just happens at the alternator.
Offline cyris426
Re: Enough CFM?
« Reply #12 on: February 04, 2015, 10:35:57 AM »
What is an fbody fan? Also, the electric fan is a must since there is very limited room for clearance without modifying the large bar that runs from side to side near the front of the car.
Offline cyris426
Re: Enough CFM?
« Reply #13 on: February 04, 2015, 10:38:11 AM »
http://www.etrailer.com/Radiator-Fans/Derale/D18214.html
This one has high amp rating and may just barley fit.
Offline cyris426
Re: Enough CFM?
« Reply #14 on: February 13, 2015, 12:46:55 AM »
Anyone know anything more about this? Cant get this car to drive without a cooling system working.
