March 17, 2025, 02:33:34 AM
Author Topic: RPM problem trying to figure out how to calibrate it correct  (Read 3995 times)
Offline rx_evo
« on: January 15, 2015, 01:11:46 AM »
Hey guys I just finished doin the Ls swap it's all doin good running strong am having a problem with the rpm guage it work good and all but it reads wrong do I need to buy something special to calibrate it so it reads correct? If you guys could help me out that would be great thanks
Guys
Offline halfspec
Re: RPM problem trying to figure out how to calibrate it correct
« Reply #1 on: January 15, 2015, 08:24:01 AM »
Assuming that it's working and you're not using a Gen IV+ LS PCM that's missing it's pullup resistor...
Is it too fast or too slow?
The RX7's tach accepts a signal of 2 pulses / rev. For reference, this is how most modern PCM's output a tach signal based on cylinder count:
V8 = 4 pulses / rev - The exception being LS PCMs which output 2 pulses / rev (good for us)
V6 = 3 pulses / rev.
4banger / rotary = 2 pulses / rev.
If you read my notes above you'll see that stock for stock the LS PCM should match the RX7's tach gauge, however, if you're PCM config has been changed to 4 pulses / rev or something else you'll read too fast or too slow and it will have to be reconfigured / retuned.
Offline rx_evo
« Reply #2 on: January 16, 2015, 03:32:36 PM »
Is it going fast let me take a video and post it so u can see thank you for the help
Offline rx_evo
« Reply #4 on: January 17, 2015, 02:40:41 PM »
Oh really because am Getting ready to tune the car will the tunner  be able to fix that proble
Offline awd-rwd racer
« Reply #6 on: February 17, 2015, 05:50:18 PM »
so you dont need a digital dakota? you can just adjust the pulse setting in hp tuner and done?
Offline GTR
« Reply #8 on: March 08, 2015, 02:27:46 PM »
What about the Holley HP ?
Mine is too high and I'm trying to figure out what to do
Offline Negrok20r
« Reply #9 on: March 08, 2015, 03:31:41 PM »
To setup a Tachometer output that operates at a different pulse frequency than what is built into the software.
You will have to add the I/O ICF – same steps as adding the Transmission and DBW ICF’s.
From there you will create a PWM output,
After this is created you will go to PWM Setup and set the output up as RPM Based.
However, you will have to do your own math to determine what multiplier and divider you need to use for your tachometer.
dc2 k20 turbo
93 FD under construction
" If you don't have time to do it right, when will you have time to do it over ? "
