March 17, 2025, 04:01:10 AM
Author Topic: 1993 Volvo 945 L33  (Read 51352 times)
Offline rallydallas
1993 Volvo 945 L33
« on: December 01, 2014, 03:19:18 PM »
About
Well, here's my build thread for my blue wagon.  I'll post up pics soon and as I complete stuff on it.  Its primary purpose is to be a long-range well-powered high-mileage trip car.  No track use planned, just fast straight-line movement  8)  (I'll probably be building out my 1988 744t for track use though  :) )
Timeline
20080112  Bought the 945 from San Diego.
20131125  Picked up L33 from Mike, cobalt964 on ls1tech.com in Piedmont, OK.
20140223  Pulled the B230FT.
20141129  Installed the L33 for hopefully the last time (for a while.)
20150913  L33 first start.
20170121  First drive on the street with L33.
Specs
Volvo Chassis Specs
Remaining/To-do list
  • Install new ignition harness
  • Finish build-out of stainless exhaust
  • Get A/C functional
  • Fix leaking passenger side Vband
  • Troubleshoot intermittent Reverse Lockout
  • Troubleshoot idle dip when coasting
  • Get front-end alignment
On my way back from San Diego (around 20080112):
[attach=1 width=500]
Just before pulling the engine (around 20131228):
[attach=2 width=500]
« Last Edit: February 03, 2019, 05:16:19 PM by rallydallas »
Offline rallydallas
Re: 1993 Volvo 945 L33
« Reply #1 on: December 01, 2014, 03:20:08 PM »
"This page intentionally left blank."
« Reply #2 on: December 01, 2014, 03:22:01 PM »
I don't know what's happening here, but I'm excited to see.  :D
Offline thekanezzi
« Reply #3 on: December 01, 2014, 04:45:52 PM »
Subbed
Offline rallydallas
« Reply #4 on: December 01, 2014, 05:18:15 PM »
Ok, so here's what I did this past weekend with the completely insanely awesome weather.
Pulled the L33:
[attach=1 width=250]
Pulled out the clutch bleeder:
[attach=2 width=400]
Installed a remote bleeder from Speedway Motors (5151399-48):
[attach=3 width=400]
Hammered on the transmission tunnel.
Re-installed L33:
[attach=4 width=400]
« Last Edit: December 01, 2014, 06:03:08 PM by rallydallas »
Offline N2v8fcs
« Reply #5 on: December 01, 2014, 05:47:53 PM »
nice!
:drive:
Offline quinns
« Reply #6 on: December 01, 2014, 08:44:44 PM »
Nice ovlov bro. What are you going to run for a diff?
Get some pics of how that tr6060 fits in there. Are you going to have to modify the tunnel? I didn't think one would fit easily but I've mainly looked at 240s.
1997.5 Hummer H1
2006 Hummer H2 SUT
Offline rallydallas
« Reply #7 on: December 01, 2014, 10:39:49 PM »
Thanks, I'm hoping to run with the stock diff for a while.  They're supposed to be able to handle a good amount of torque, but we'll see.  If not, then it'll be Ford 8.8 time.
I can get pics of the Magnum fit, no problem.  I only had to hammer on the passenger side tunnel near the firewall.  After that (and having that Holley oil pan and the set-back shifter) it fits like a glove!
Offline rallydallas
« Reply #8 on: December 05, 2014, 10:09:00 PM »
Started messing with the injectors.... You'd think I would have done this months ago  :banghead:
[attach=1 width=400]
Measurements on that injector from right to left: 10mm, 13mm, 13mm, 8mm.
« Last Edit: December 05, 2014, 10:25:27 PM by rallydallas »
Offline Darth Viper
« Reply #9 on: December 09, 2014, 12:25:53 AM »
I wouldn't count on it living long.
Boost Evangelist
"rotary's are like boats, awesome things for your friends to own..."
See me for all of your nuclear power plant needs.
Offline quinns
« Reply #10 on: December 09, 2014, 02:21:46 AM »
I wouldn't either but some of that Volvo stuff is surprisingly stout.
1997.5 Hummer H1
2006 Hummer H2 SUT
Offline Darth Viper
« Reply #11 on: December 09, 2014, 07:21:11 AM »
I'm going 8.8 on my 4 cylinder turbo build. I don't trust a stock diff over 350-400 HP.
Boost Evangelist
Offline bikedad
« Reply #12 on: December 09, 2014, 09:35:13 AM »
In for the win.  :)
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
Offline rallydallas
« Reply #13 on: December 16, 2014, 10:57:46 PM »
Starting to look more and more like a real engine
Offline rallydallas
« Reply #14 on: December 16, 2014, 11:18:40 PM »
Here's some quick pics of my clearances; I'm at 1/2 inch everywhere, at least.
Throttle body with hood:
[attach=1 width=300]
Oil pan with crossmember:
[attach=2 width=300]
Passenger side tunnel, hammered, with Magnum reverse-light switch:
[attach=3 width=300]
Driver side tunnel with Magnum and remote bleeder:
[attach=4 width=300]
Underside oil pan and rear of crossmember:
[attach=5 width=300]
Passenger side, there's more room there than it looks like:
[attach=6 width=300]
Driver side, steering rack, crossmember, and mount:
[attach=7 width=300]
Rear of LS6 intake, a good bit of room in front of the firewall:
[attach=8 width=300]
