March 18, 2025, 05:50:10 PM
Author Topic: front strut conversion  (Read 39842 times)
Offline 1320king
Re: front strut conversion
« Reply #135 on: August 14, 2016, 11:22:23 PM »
Spring rate in simple terms is what ever the lb rated on the spring, is the amount of weight required to compress the spring 1"
So if you had 600lbs over the nose of the car / pushing down on the front struts then a 150lb spring (remember 2 springs) would compress each spring 2"
So now figure those 2 inches are preloaded, like a snake ready to strike  :chug:
HAVE ANY PICS???
You're correct on the spring rate definition, but when installed on the car the suspension geometry provides a leverage ratio, making wheel rate different (usually lower than) spring rate.
With 150# springs, a 600 lb load would compress the suspension substantially more than 2".
You are 100% correct! I didnt want to confuse anybody I was just giving rough and tumble / simple explanation.
Offline 1320king
« Reply #136 on: August 14, 2016, 11:30:25 PM »
superslow what did you do to make those work btw? Strut tops etc
Offline SuperSlow
« Reply #137 on: August 17, 2016, 04:00:30 PM »
Used the same camber plates as phish. Then a copper pipe coupler, which I had to cut down and rework into a circle, as a shim between the camber plate and the strut since there was about 1/8" difference between the inner diameter of the plate and the strut itself.  I also used a steel coupler type deal (not sure what they called it at lowes) to space the strut hat properly.
Part numbers are as follows:
Strut- HR606SK
Spring-12HT150
Won't have a chance to try out the new springs for a few weeks but I'll report back once I do.
Offline 1320king
« Reply #138 on: August 17, 2016, 05:13:37 PM »
What is the steel coupler? hahaha not sure where that would go.
Offline SuperSlow
« Reply #139 on: August 18, 2016, 10:48:57 AM »
It's just so that I don't have to crank the top nut down a lot. The strut shaft was just barely hitting the hood without it.
Offline 1320king
« Reply #140 on: August 18, 2016, 03:19:23 PM »
ohhhhh ok, I get it now! Wow I gotta try that next!!!
Offline SuperSlow
« Reply #141 on: August 25, 2016, 02:27:24 PM »
Lol, yea it's kind of hard to describe without a pic.
I'll get you a good picture of the whole assembly when I swap springs.
Offline 1320king
« Reply #142 on: August 25, 2016, 04:52:24 PM »
sounds good! thanks man. Testing on the street so far with my setup is pretty good. A LOT better then before.
Offline Phish
« Reply #143 on: August 26, 2016, 12:39:10 PM »
Went to the track about a month ago,  With the Lakewood 90/10 fronts, Viking double adjustables in the rear and a solid axle out back, i went 1.39 60 ft.       I had way to stiff springs in the rear at the time, had the shocks set to full soft compression and full stiff rebound.   I bought new springs for the rear.  Went from a 225# spring to a 150# spring.  Hopefully this will give me room to use my rears like they are supposed to be.  We will see next time i make it to the track .
Offline SuperSlow
« Reply #144 on: August 26, 2016, 02:16:20 PM »
That's awesome man, congrats!
How fast was the overall pass? Any video?
Offline 1320king
« Reply #145 on: August 27, 2016, 09:46:55 AM »
Thats awesome to hear!! I went with 110 rear spring. was thinking about going up to the 150. The 110 seems to be too light.
Offline PapioGXL
« Reply #146 on: August 27, 2016, 12:05:53 PM »
I just got my QA1's and camber plates in. Waiting on my coworker to open the bore of the spacers that came with the plates from 15mm for the FC to 16mm for the Camaro strut.
I was able to use the stock strut brackets like Scottie did. And no welding required.
Offline 1320king
« Reply #147 on: August 28, 2016, 11:59:12 AM »
any pics? And are you using the same qa1's that superslow used?
Offline rex388
« Reply #148 on: August 28, 2016, 05:32:36 PM »
1320 I went 150# in the rear and I was able to plant the tires very nice at a no prep event. And driving around it feels nice.  Well as nice as a ladder bar can feel lol.
Offline 1320king
« Reply #149 on: August 28, 2016, 06:40:33 PM »
Ya, I am thinking of doing that.
