More work, but possibly more return on investment. Thank you very much for sharing that.
I guess I will check hood clearance for this V6 just bolting it to the existing pair of front bolts for the subframe, then get to sectioning as practical.
As to the rear suspension, I'm going for a 3-link, with the car's stock lower trailing arms, possibly shortened an inch or 2 so they don't attach behind the axle, that looks stupid, and a top center link, possibly the same length as the lowers, then move the Watt's link to be chassis-mounted, behind the bottom center of the axle. To attach it to the axle, I bought 2 feet of 1.5" x 1.5" x 0.1875" mild steel square tubing. I'll weld this to the leaf spring pads GM welded to the bottoms of the tubes, and have them extend far enough back to clear the diff. Speedway offers a kit for $ 70 that will help,
http://www.speedwaymotors.com/Watts-Link,3398.html?gclid=CNzUxJDhpMECFWqCMgodciUAZw and I got a pivot off a '98 Lincoln.
Yesterday I redrilled one rotor successfully, and made progress on the "new" axle.
