So, here is a shot of the front swaybar/reinforcements in progress:
Don't mind the booger welds on the tube to the frame on the front. The metal had a nasty spot on the frame rail that kept contaminating the weld. It was just to hold it in place while I did the rest of it, and that area will get boxed in anyway.
Here is the rear axle (mostly) finished up:
Specs are:
Factory '67 Mustang rear, stock width, adjusted to be centered with early Ford "big bearing" ends using tapered bearings with seals.
31 Spline Axles, custom length
Wilwood 4 piston Dyanlite calipers with parking brake (internal)
Detroit Locker ratcheting style diff (deburred and powder coated)
Ford OE 3.70 Gear Set
Yukon Nodular Iron 3rd member housing
Aluminum Daytona style pinion support
Timken Bearings throughout
Solid pinion spacer
Billet Steel 1350 Yoke
I had to clearance the Yukon as the Detroit Locker carrier fouled on the pinion pilot support area when I tightened up the backlash up to spec. A bit of time with the grinder and she's got .125" clearance now.
I added a drain bung to the housing so that I don't have to disassembly Johnny 5 to swap out fluid in the future (because pulling this axle off of the torque arm is a bit of a PITA and the 3rd member can't come out with the torque arm installed).
I'll tear it down, add a couple brackets to lock the hard lines in place, paint it, order braided lines for the ends and final assembly the outside in the next couple weeks. The diff itself is (hopefully) final installed and sealed up.
