How do you know you're a car guy (and possibly an idiot)? You buy nice brand new parts, open the box, hack them up with a bandsaw and weld them back together.
In related news I put the new elbows on my new intercooler. It should fit fantastic. I figured out how to lay out my cooling system (I think) for version 2.0. Basically the new, much larger, intercooler will sit on the engine bay side of the front core support (vs. the old forward of core support area) and will sit high up, bolted to the factory crossbar that I previously setup to be removable and boxed. I'll modify the crossbar with some tubing dropped in to support the intercooler bolts/dress it up a bit, then build some lower bracing.
The factory crossbar between the frame rails (which isn't super needed with my other work I've done) will get notched for the oil cooler, which will sit low in the front, to keep it from pre-heating the intercooler. It will sit in the Shelby lower valance opening like they did the Trans Am cars back in the 60s:
Behind the intercooler/oil cooler area will be the radiator/condenser. I'm going to weld some bungs to the radiator and then bolt the condenser directly to it (with phenolic washers for heat separation). The whole shebang will then get shrouds made out of aluminum to duct everything through properly. I might grab a dimple die kit for some of the bracing, just to dress things up a bit.
The new IC is the same one I ran on my FC to good results, so I think it should work well (CXRacing 24x12x3 core). Plus having 3" inlet/outlet will look much better than the 2.5" on the old one, that just really, really, really bothered me, appearance wise. I do have to redo most of my charge pipes but that's not a big deal. I also picked up a JGS 50mm BOV (same one I had on the FC) that I'll get added in shortly as well:
Here's my Speedway swaybar. I'm still waiting on the bushings to come in so that I can order a tube to mount it with (sleeves + bar will slide into a thick wall tube, which will get welded to the frame and braced):
And the new, new shifter for the TR6060. This is an MGW and it is NICE. Wow is it nice. Comes with a boot and all kinds of stuff. Very impressive, though it really should be for 400+ dollars, so.
