March 18, 2025, 05:50:22 PM
Author Topic: Blake's 1965 Mustang Project  (Read 613262 times)
« Reply #915 on: February 02, 2017, 04:12:34 PM »
Ahh you got screwed with the JORDAN INNOVATIONS script on your fuel gauge too I see.
« Reply #916 on: February 02, 2017, 04:43:05 PM »
LOL, and Blake can't wait to see the finished product
« Reply #917 on: February 02, 2017, 05:54:57 PM »
So I built some wire holders and LED bulb holders (For the signals) for the cluster, but the main thing I played with tonight was this:
Custom Rally Pac rendered in Fusion 360.   I'll print it shortly for mockup.  :)   The "FORD" text will probably get removed or tweaked a bit.   You can't see it in the render but there's a 5/16" passage that runs between the gauge pods and out the back of the center support to run the wires out of.
That looks great, can't wait to see it printed.
« Reply #918 on: February 03, 2017, 10:35:32 AM »
So my printer jammed for some reason about 8 hours into this (it's a 20 hour print, LOL), but it left me with a usable mockup.   Here's the 40% completed piece:
The hole for feeding wires (hard to see, it's just above the middle of the picture):
And the output from the wires:
It's rough as I didn't do any post processing and it's printed at "draft" quality.   I'm not sure why I got a jam, it's cheap filament, so maybe there was a diameter change and it skipped.  I'll restart it tonight and tweak the tension on it a bit.
Offline gc3
« Reply #919 on: February 03, 2017, 11:12:45 AM »
like.
« Reply #920 on: February 03, 2017, 12:52:14 PM »
sweet!  that sucks it jammed
« Reply #921 on: February 04, 2017, 09:12:52 PM »
BOOM.
SUPER stoked with how it came out.  There is a small glitch where the drag chain on my printer was hanging up, but it'll clean up fine.   The logo is for my build blog, and I think it's catchy.   Little details.
« Reply #922 on: February 04, 2017, 09:21:35 PM »
Awesome!!!!!
« Reply #923 on: February 05, 2017, 02:09:12 AM »
Very Cool!!!  :bacon:
Offline FC3S Murray
« Reply #924 on: February 05, 2017, 08:50:35 AM »
Nice touch Blake. Set apart from the rest.
SRM Performance Tuning LLC
« Reply #925 on: February 05, 2017, 01:32:07 PM »
Finally finished seam welding the floorpan replacement areas that the PO half-assed under the car.   I also worked the floorpan for more exhaust clearance.    Pro tip:   Removing seam sealer, welding, grinding and dressing above your head sucks, even if you have a lift.
Now I'm putting on 3 coats of Duplicolor Bed Armor bedliner under the entire car.   I like the rough texture of it and it really evens out all the areas underneath.  It should be pretty damned durable also.     Pro tip 2:  Applying bedliner above your head also sucks.
I plan to do the entire interior with Lizardskin once I'm that far along.   That's an expensive endeavor, wowza.   I think I'll also wrap the exhaust near the transmission, just to further keep heat out of the interior.
Next up is the fuel/brake lines though, and then finishing out the firewall holes that need it, then adding the front swaybar, and finally staring at the cooling system for a while to see if, and if so, how, I want to adjust it.
« Reply #926 on: February 05, 2017, 09:24:39 PM »
Next item on the list, a rotisserie!!!
« Reply #927 on: February 05, 2017, 10:26:37 PM »
Haha, nah.   If I had one a long time back it'd have been great, but at this point I'm done underneath minus some fuel/brake lines and a few small tweaks.   And I swear on everything holy I will never do a restoration of this depth ever, ever again.
Oh, while I was at it I removed the driveshaft loop that was built into my 3 link/bracing kit.   It was going to be too close the driveshaft, too far forward and was in the way.   I'll build a new one at some point once everything else is fitted into place.
« Reply #928 on: February 06, 2017, 09:04:13 AM »
Come on you don't wanna restore an FC in 20 years?  Gauge pod looks awesome.
« Reply #929 on: February 06, 2017, 09:09:51 AM »
If I was starting this from 0, I'd have picked up like a 1993 Cobra or maybe a 2003 Cobra as a base instead.   Probably a C6 Corvette though.  Haha.
