March 16, 2025, 06:01:00 PM
Author Topic: Blake's 1965 Mustang Project  (Read 612765 times)
« Reply #45 on: October 16, 2014, 08:09:53 PM »
By "nothing" he meant Big Block Ford.
Offline quinns
« Reply #46 on: October 16, 2014, 08:29:15 PM »
hahaha definitely meant a big block ford. Looks like you got your work cut out for you but pretty good bones for a car its age.
1997.5 Hummer H1
2006 Hummer H2 SUT
Offline jax04
« Reply #47 on: October 16, 2014, 08:37:12 PM »
Awesome Blake!
I swear i will get up there soon to grab whatever parts i left behind. lol.
So, whats first on the agenda???
Offline Speedfab
« Reply #48 on: October 16, 2014, 09:44:02 PM »
I like.  Can we start it now?  What's the plan?  How's it coming?  Do I need to come up there and "Fred" ya?
How about now?
Now?
Offline jparker7
« Reply #49 on: October 16, 2014, 10:15:38 PM »
wheels look perfect
Offline N2v8fcs
« Reply #50 on: October 17, 2014, 09:11:34 AM »
Yeah the wheels  fit pretty well. Did you have to put spacers behind them?
:drive:
« Reply #51 on: October 17, 2014, 10:28:35 AM »
No spacers out back at all.  They are TIGHT but fit.   Front needs spacers which I ordered today.
First on the agenda is fixing a few patches I found in the body behind the fender, getting the panels aligned and shaving the drip rail.   Then subframe connectors and front suspension and brakes.
Offline stbrn19
« Reply #52 on: October 18, 2014, 05:13:44 AM »
Looks good, I'd like to tinker with something like this but have too many projects already.  Maybe someday. Until then, feed me updates pleaaaase.
« Reply #53 on: October 18, 2014, 06:53:42 PM »
Here's a shot of the area behind the half-ass patch on the cowl side panel.  I cut out the weak metal and made this patch in a few layers to mimic the stock flanges so that it looks correct.   You can't see this area with the fender on, but I would know if it was half-ass...  ;)
Before:
After:
I also seam welded the toe panel (floor pan to firewall piece) since I didn't think it was installed with as many tacks as I wanted and it's somewhat structural in the unibody.    Much more rigid.   I also found that the forward area of the cowl panel was attached poorly so I cut it back, cleaned everything and folded it over to make a smooth transition.  Looks stock and is much stronger than the original design.   Again, you can't see these areas, but those details are what makes a good build.
I did decide that the cowl panel itself needs replaced.   This is a common issue on early Mustangs.   It's only a couple hundred dollars but is a fair amount of work.   I will order it as well as torque boxes (reinforcements between the frame and rockers/floorboards) for installation soon.   The 65-66 cars didn't have torque boxes, which hurt rigidity, but they can be added.    After that I should have a good body all around and then get started on some reinforcements and modifications.  :)
« Reply #54 on: October 18, 2014, 07:40:21 PM »
And the front driver's side of the car cleaned, etch primed, sealer primed and coated in bed liner.   I did not bother with the shock tower since it will be going away anyway when I update the front suspension.
And a shot showing the inside of the cowl.  It's probably repairable, but if I'm going to rip it open, I would rather just replace it all.
Offline Supe
« Reply #55 on: October 18, 2014, 08:51:28 PM »
Damn dude... you move fast!  Looks good so far.
« Reply #56 on: October 19, 2014, 12:21:43 AM »
Thanks!
The car had an old Grant steering wheel in it with a wooden rim.   I'm pretty sure it's rather "vintage" as the car was last plated in 1977.  It was pretty rough with the varnish peeling off.    I sanded the old varnish off and am redoing it in a dark mahogany finish with a satin varnish.    Should come out pretty well and I think it suits the car well.   I'll get some pictures when it's done.
Offline quinns
« Reply #57 on: October 19, 2014, 01:27:30 AM »
You sure aren't wasting any time. That cowl looks like a fun one.
1997.5 Hummer H1
2006 Hummer H2 SUT
Offline Supe
« Reply #58 on: October 19, 2014, 10:54:28 AM »
Good call on the wheel.  On our Firebird (79 model year), we found a vintage Momo wood grip wheel that was a dead nuts match for the wood grain on the dash.  Looked a thousand times better than the cheapie aftermarket wheel that was on it.
« Reply #59 on: October 19, 2014, 12:06:50 PM »
Not messing around!
