March 16, 2025, 02:30:50 PM
Author Topic: Blake's 1965 Mustang Project  (Read 612746 times)
« Reply #2895 on: October 22, 2023, 04:46:44 PM »
Installed the C6 fan control, loose ground, and (hopefully) a tiny oil leak.   Also moved around the injectors to see if that impacted the higher EGT on cylinder 3.  It did not.  So I reckon it's an issue with where the sensor is, depth wise.  I'll check that next, but no big deal overall.
Just about there...
« Reply #2896 on: October 28, 2023, 03:34:34 PM »
Fan control worked great on a test drive.  Put about 15 miles on the car.  Have a tiny coolant leak (loose clamp I think).  No other major issues.   Speedometer and fuel level appear to be working now.   Playing with fuel and cam timing now.   It'll go for winter hibernation soon, and I'll sort out the remaining details in the spring.
Offline Venom13132
    • Venom Speed Shop
« Reply #2897 on: October 30, 2023, 07:23:05 AM »
nice work!  Too bad the season has passed.
« Reply #2898 on: October 30, 2023, 12:39:52 PM »
Fixed the coolant leak (loose clamp).
I had a small oil leak at the oil filter relocation fittings.  I dropped the alternator, pulled that apart, spent 2 hours to find a damaged o-ring and slightly loose fitting.  Fixed that... and it leaks worse.   Fun.
Going to nuke the setup that's in place there, as it was done due to space with the old suspension/steering setup.  I have WAY more clearance now, so I'll put in a much simpler setup now which won't leak.   Parts will be in tomorrow.   I want to validate that, check a few other details, and it should be ready to go.
Agreed on the end of season, but I'm psyched to get to work on the Aston as well.   I'll have lots of tweaking to do on two cars next season, haha.
Offline Venom13132
    • Venom Speed Shop
« Reply #2899 on: October 31, 2023, 08:16:33 AM »
yeah, I am excited to see the Aston project move forward.  I watch every Vantage that gets listed on BAT.  If I weren't doing a $350k addition to my home, I would buy one.  I just saw one sell for $30K last week.  It has 70k miles but so cheap.  I still need to stop by one of these days when I come up to the In-laws.  We will probably be in Auburn on Thanksgiving but just for that day likely.  Maybe in the spring we will go visit them and I can swing over.  Or in the summer if my car is finally back together.
« Reply #2900 on: October 31, 2023, 11:17:40 AM »
Sounds great!   I'm always busy on weeknights, but weekends are free if I'm not fighting in a tournament.   :)
« Reply #2901 on: October 31, 2023, 11:28:57 PM »
Got the fittings in and redid the lines.  No leaks!   I think it's running well enough to get it to my friend's place for winter storage.  This spring I'll get it back out and sort out the tune details and hopefully get it on a dyno finally.
« Reply #2902 on: November 06, 2023, 04:08:24 PM »
Made the 35 mile drive to my friend's place for winter storage without any drama.   Had a small drip of oil from up front somewhere (not the area I fixed) that I need to look into.  Not sure if it was charge pipes spitting a little oil (which would mean my compressors are still spitting a little bit) or if it's my breather tank.  It looked like breather tank, but that's springtime Blake's problem.  LOL
« Reply #2903 on: April 29, 2024, 09:00:27 AM »
Well, 6 months later, car is back out of storage!
Went to my friend's house, hooked the battery up, touched the start button and it fired up and drove like a champ.  Tune still sucks at load (fine at cruise).  Something different in the setup in the Nexus vs. the Elite I guess as the tune was fine on the old ECU.   Anyway, that's fixable easy enough.
Car ran fine on the drive home, no drama.   I need to figure out the oil leak issue.  I think it may be on the compressor side of the turbo and blowing out the BOV, but I'll have to pull the charge pipes off and see if that's the case.   If it's turbo drainage... again...  I'm putting oil-less turbos on it.    They can't leak oil if they don't have oil and I'm done with messing with them.
Offline Venom13132
    • Venom Speed Shop
« Reply #2904 on: April 29, 2024, 10:09:37 AM »
hah sounds like a good plan forward
« Reply #2905 on: May 05, 2024, 08:19:38 PM »
Screw it.
Oil-less turbos en route.  I'll have my old ones for sale (nothing wrong with them, just can't suck enough oil out with my setup, along with a Turbowex Exa-Pump, check valve, and TurboSmart OPR and filter assembly.
I should have done this 3 years ago.
Offline cholmes
« Reply #2906 on: May 05, 2024, 10:20:19 PM »
REALLY looking forward to your review of the oil-less ones.
« Reply #2907 on: May 07, 2024, 05:09:36 PM »
Spent a few minutes and whacked on a 90* adapter with the TIG.  I'll snag some VHT 2000* to coat the turbine housings to minimize surface rust (it does a shockingly good job in my experience) and these should bolt in place.   I'll see once they're in if I have enough play in the exhaust to line it up, it should be REALLY close to the VS Racing units I have in place now and the flanges are all the same.
My water fittings should bolt right up, and I'll toss some AN fitting caps on the feed/return fittings on the motor and it should be ready to rock.
I do have a few other items left on the list.   I put both CAN buses on one... bus, and it was noisy, which made the keypad mad.   So I need to divorce the secondary bus.   That's just making a quick adapter and moving a couple plugs over to it, so not a big deal.    Once that's done and I can actually signal and honk the horn, I'm going to start putting miles on it and sorting out the tune.
The tune still confuses me a bit as I imported my Elite 2500 tune into the R5, but it's FAT everywhere.   Dunno.   But it runs great where I've leaned it out, so I'm sure there's a table somewhere that is different between the two.  I've honestly not spent a ton of time working on that yet, so I'm somewhat excited to get it dialed in and start turning the boost up a little.
These are actually SMALLER turbos than I've been running (57mm vs. 62mm) with a similar size exhaust housing.   As I have zero plans to forge this engine, the ~625-650 RWHP range remains my target, and I'll trade some peak HP capacity for nasty fast spool.   Considering the displacement I think this setup should be a lot of fun.
Anyway, I'll throw these on this weekend, find out all the things I didn't think of, cuss a bunch, and then get annoyed and work on the Aston Martin the rest of the weekend.  Probably.
« Reply #2908 on: May 07, 2024, 09:47:31 PM »
I am curious how the longevity of the oilless is.
« Reply #2909 on: May 08, 2024, 07:11:29 PM »
I wouldn’t run them on a daily driver, for sure.
At ~1500 miles a year, I expect they’ll be fine for my needs.   If they poop themselves I’ll put a blower in it.
