March 17, 2025, 11:18:03 PM
Author Topic: Blake's 1965 Mustang Project  (Read 613108 times)
Offline cholmes
« Reply #2820 on: February 20, 2023, 02:25:44 AM »
Cobranut mentioned something really important about drilling / tapping / machining cast iron: always do it dry. Cutting oil just screws things up. Don't know why, just does. This info came from none other than Mac Tilton, and I've verified it many times with my own projects.
« Reply #2821 on: February 21, 2023, 08:41:15 AM »
I bought brand new cobalt bits and an Irwin tap, and didn't have too much issue at all.    One drill bit started to get a tiny bit dull by hole 7, so I swapped to a fresh one, but I probably only have 30 minutes across all 8 holes, so I'll take it.   I expected much worse.   It tapped really nicely, as well.
I am fighting a little with interference with my steering.   I only have about 1/8" of clearance with the upper u-joint in the steering linkage, where it comes close to the wastegate clamp.    Well, I did.   Right now I have 1/32" of an inch, with no clamp in place.   This is because I raised the engine/transmission slightly, and moved them over to the passenger side slightly.    I validated clearance before I adjusted height of the engine, so it's not the lateral movement.
So I need to play with my height shims slightly to get it as high as possible while keeping steering clearance.   I knew this would be the case though, so at least it's not unexpected.   With the amount of crap shoved in this engine bay, it's not a game of inches, it's a game of millimeters.   Once I get the driver side sorted, which is much busier, I'll get the passenger manifolds in.   On that side I have to dodge the control arm.   The upper arm has to be left loose for the exhaust manifold to go in.  Once that's in, I can put the arm on easily, but it's annoying to have to do it this way.  Oh well.
The EGT probes all fit fine though, so that's a start.  :).   I'm hoping to finish the manifold yoga this weekend and get the turbos installed.    Then I will get the turbo oil pressure regulator moved (it was too close to steering) and those lines built, then probably exhaust mods, then charge pipes.
Oh, my AC compressor hits the suspension too.   Well, the AC lines exit directly into it.   So I'm changing to a Sanden SD7 as it's more compact and has tons of options to adjust hose output location in a compact way.   This will also give more clearance for my charge pipes which run right by it, so it's a win-win.  Other than my wallet.  That didn't win at all.
« Reply #2822 on: February 24, 2023, 09:49:52 AM »
Exhaust manifolds are both in.   One of the exhaust manifold bolts interferes with installing an EGT probe, so I'll swap that to a button head to get the 1/16" clearance I need to tighten the cinch nut on the probe.
I fiddled with engine position and fixed the clearance, so that's good.   Next is the turbo oil plumbing, starter, new starter power, then turbos and exhaust work.   Getting there!
« Reply #2823 on: March 13, 2023, 11:01:57 AM »
I'm editing a quick video overview of progress, but in the meantime, finished the second brake caliper bracket install:
I need to install the alternator, and wire it and the radiator fan PWM controller up, then I can install both turbos and the AC compressor, and start building charge pipes and tweaking exhaust fitment.
Offline babillaracing
« Reply #2824 on: March 13, 2023, 10:07:40 PM »
Looking really good bro
« Reply #2825 on: March 23, 2023, 08:57:32 AM »
Got the big power run up front;  I still need to get the ground lead put back in.   I have a 2 AWG from the battery that runs all the way to the engine bay, where I'll put it on a post, to tie the engine and fan grounds to.   I can just tie to the frame, technically, but this should be a little better layout.
Turbos are in place and one of my existing downpipes mates to the rear exhaust, so I only need to do one of them, which is nice.   I'm rebuilding all new coolant and oil lines since the old ones are a few years old now and they're not PTFE.   Hoping to get the oil and coolant lines to the turbos done this weekend.   If I am really efficient, I might be able to get the exhaust done and start working on the charge pipes and cooling system ducting.
Once that's done, I need to get the hydraulic hand brake in, finish a few wiring details, then start on that new center console.
« Reply #2826 on: March 23, 2023, 10:48:25 AM »
How it working with PTFE hose?  I just dabbled into the AN world this winter but it was just rubber hose and lines on my 500hp snowmobile.  I wanted to re-do the RX7 with PTFE some day.
« Reply #2827 on: March 23, 2023, 12:46:54 PM »
I prefer it.   The “olive/acorn” is fussy at first, but once you get the hang of it, it’s not bad.    The hoses have been less leak prone over time in my experience as well.
I’m slowly transitioning all the soft lines in my car to it.
Offline shainiac
« Reply #2828 on: March 23, 2023, 01:12:47 PM »
I agree with Blake. Once you learn how to work with the PTFE stuff, it's faster and easier to assemble. I use a blunt-ish pick to pull the braid back from the PTFE core so I can install the ferrule and everything else goes together well. The small 3AN and 4AN tubing can be a pain, since it's more flexy. When trying to peel back the braid, it's easy to stab yourself in the thumb with the bare braid.
My biggest grip is that the PTFE doesn't really tolerate tight bends. It will bend and bend and suddenly kink and the ID will not return to its original size.
BMW DCT Swap, Ronin 8.8" IRS
« Reply #2829 on: March 23, 2023, 10:58:09 PM »
I use PTFE from racetronix that has a solid outer sheath. Just trim the acorn depth off and assemble. Super easy.
« Reply #2830 on: March 24, 2023, 10:11:36 AM »
Forgot that I changed AC compressors, and need to build new lines.
In proper “I hate shopping things out” form, I bought a crimper so I can do it myself.    A friend has a vacuum pump/charge setup I’ll borrow when ready.   I’m amped to get AC working finally.
Offline shainiac
« Reply #2831 on: March 24, 2023, 11:16:18 AM »
Maybe a dumb question, but why not use AN for AC lines? pressures and temps are lower than what you'd see in an oil cooler line I think.
« Reply #2832 on: March 24, 2023, 05:05:21 PM »
Mostly because the compressor, condenser and dash components use o-ring style already.
« Reply #2833 on: March 24, 2023, 08:20:14 PM »
Take a look at ES-12A as a refrigerant. It's propane and butane based but more effective than R-12 and at lower pressures. Also needs no vacuum. It's recommended to fill at atmospheric. Also a large molecule and less likely to leak. It's just...flammable.
With R-134a I'd need over 20oz. ES-12a only needs about 9oz.
« Reply #2834 on: March 24, 2023, 08:47:25 PM »
Innnnnntersting.    Everything else in the car is already flammable, so.  Haha
