Mine won't be super heavy duty or anything, goal is to NOT extra weight this time, since I paid zero attention on the first go-around.
. It should be enough to keep it from whacking the pan/turbos, as long as I don't do anything toooooo stupid.
I did some work yesterday. Pulling the engine in/out on this car has always been a pain as my lift/leveler just BARELY hit the hood at the point the engine needs to be at to come out, and I HATE pulling the hood on this car as it sucks to move/install/align and weighs roughly 1 ton. A glass hood is on my "eventually" list... Anyway, I was staring at the load leveler about to pull the engine and thought "hey, if these chains were shorter, it sure would make this easier.." Yeah, duh. I can make that happen. So took 2 links out of each chain and BOOM, life is much easier! Wish I did that 3-4 years ago...
Anyway, I finish welded the lower radiator mounts/front cross braces, those are good to go now. I also finish welded the engine mounts, though I need to fab one more plate for each side to get a little extra strength in them. I also notched the subframe for intercooler pipe clearance under the A/C compressor as it was tight there, and a notch is easy to do right now. The plates for all of the subframe notching are cut, tacked and ready to TIG up. I would have done more, but I hurt my knee a bit in a tournament on Saturday, and getting up/down 500 times working on the car was making it worse. Hopefully I'll have a few nights this week to get the plating in done, then I can do that skidplate "frame".
Once all of that's done, I'm going to go over a bunch of the welds with seam sealer, then get everything sealed/painted, and put the drivetrain back in. List after that is:
New "hot side" intercooler pipes
Redo exhaust section from turbos to mid-pipes as I did have to move the turbo angles slightly
New lower radiator pipe/hoses (I'll build these out of aluminum)
Close-out panels around the suspension to finish out the engine bay better
Finish a little bit of engine bay wiring from the Nexus re-work (mount MAP sensor, wire new combo oil temp/pressure sensor, etc.)
Finish new A/C system work (changing to a Sanden compressor due to clearance issues with the OEM Ford one)
Build brake caliper brackets on steering knuckles
Build new front brake lines
Mount hydraulic hand-brake handle and run fluids to/from it.
Build new center console around new hydraulic hand-brake
Align suspension
Wash/buff car
I'm sure I'm missing a bunch, but that's most of it.
