The Camaro is gone, so I can work on MY CAR! Yay!
So, winter plans as of now:
1. Quick ratio steering rack. This is already installed, just need to torque some bolts.
2. Front sway bar. Ordered new mounts, will fabricate arms.
3. Full proper alignment. I bought a full string alignment setup, some Torrington bearings for the front shocks, poly bushings for the front lower arms, corner scales and training about how to use it all.
4. Center console rework. Going to new HVAC controls I designed, cleaned up window switches, CAN keypad and doing the forged carbon plate for it.
5. Bluetooth stereo/amp. Hidden, because I don’t need a head unit in 2020.
6. Floor mats and visors. These are done!
7. Redo the wrap on the rear inner quarter panels by the back seat. It delaminated some. I bought better glue this time.
8. Cruise control/CAN integration. This goes with the CANbus keypad. Going to integrate a custom CAN network into the Haltech myself since they won’t enable it...
9. Turbo oil drain rework. I’m backing up oil in the turbos sometimes. Going to sort that out. I have a plan...
10. Upgrade fuel pressure regulator and oil/fuel pressure senders. Going to a higher quality FPR and senders to eliminate any question on behavior and accuracy of readings. No more eBay sensors!
11. Fix the alignment of the driver side window. It rolls up a bit crooked.
I also want to polish the paint again and maybe get the windows tinted, but those are on the “maybe” train. And fix AC this spring!
If I can sort this all out and get the tune 100%, I think the car will be what I’d consider properly sorted, finally!
