March 18, 2025, 05:42:36 AM
Author Topic: harkey25 turbo build in process  (Read 9869 times)
Offline harkey25
« on: September 07, 2014, 07:28:23 PM »
this will be updated as i complete each step and so on first off here is were i car is
Engine:
- JimLab/Dynotested LSX - Rx7 LS1 conversion kit: subframe (powdercoated), tranny mount (powdercoated), driveshaft, and bump stop correction
-1999 Ls1 engine/trans with approx. 40,xxxx miles currently
- monster stage 1 clutch (about 5,xxx miles)
-JTR 1 3/4" ceramic coated headers
- bored throttle body
- LS6 intake manifold.
- Hinson Super Cars radiator/cooling system
- Hinson Super Cars Cold air intake
- Modified new AC lines with new condenser and evaporator
- working power steering
- Corvette LS2 oil pan (has better baffling for better oil temp control
- Custom 3" exhaust into magnaflow muffler
Chassis/wheels:
- polyeurothane steering bushings
- bump stop correction
- polyeurothane rear diff bushings
- Rear end with 3.90 gears and FC clutch-type limited slip differential
- Samberg rear diff brace - powdercoated (replaces torque arm to eliminate wheel hop and strengthen differential)
- 18x9 and 18x10 Work Meister s1 3-piece wheels wrapped in bridgestone tires with at least 75-80% tread left
Interior/audio:
- Mustang cobra 6 speed OEM shift knob
- pioneer bluetooth navigation headunit
- (2) 6.5" JL audio component speakers in custom enclosures that look OEM
- (1) 8" image dynamics sub in custom enclosure
- (1) 400w 4-channel JL audio Amp
- battery relocated to passenger rear bin
- new custom trunk floor carpet to match OEM
Exterior/Lighting
- New R1 OEM front lip spoiler
- FEED replica sideskirts
- Audi A6 Bixenon HID projectors Retrofitted into OEM housings
- Smoked parking lights on front bumper
My plans are 76mm build try to keep the ls1 for as long as i can and hopefully be around 7-800whp mark street driven is the goal thanks for looking i can use all the help i can get
Offline Tictakman
Re: harkey25 turbo build in process
« Reply #1 on: September 07, 2014, 07:46:44 PM »
someone is selling a single turbo manifold setup for ur build in the classified section.
Zak
Offline harkey25
« Reply #2 on: September 08, 2014, 05:39:53 AM »
I saw that I was thinking more of making one myself when it come time for that the first big thing I'll buy will be the Cobra rear
Offline harkey25
« Reply #3 on: September 14, 2014, 03:01:17 PM »
so i took the car out last night for a little meet was was deff surprised how well it stood up to cars making 100+whp i threw it on the dyno for a base line and was deff surprised that it made 324whp on that dyno i will post a pic when i get home
Offline harkey25
« Reply #4 on: September 14, 2014, 10:13:11 PM »
This was the only photo I took
Offline harkey25
« Reply #5 on: November 30, 2016, 07:41:14 PM »
Ok so I think it's time to update this real quick lol well the ls1 got a cam lasted a bit but ended up eating the crank [emoji20]
So I was in the process of getting the ls1 built but a buddy decided to give away a nicely built 408 so I picked that up and some nice bnib dart pro ls3 style heads compression should be around 10.5-1 so it's going to be a e85 car from now on
Now am just kicking around in my head to stay stick or go auto
Offline harkey25
« Reply #6 on: April 24, 2018, 11:57:57 AM »
So I totally forgot about this but here are some progress pictures of the build and I did end up going auto to a 4l80 and what not and made the jump to run a holly dominator ecu setup
Offline harkey25
« Reply #7 on: April 24, 2018, 12:03:59 PM »
Also spent a good part of the day trying to figure out how to run the drive belt due to the fact I am now running a electric water pump and this is what we came up with
Then we realize that we didn’t really have any room for the oil return from the turbo and we made the decision to cut the ac belt ring off the pulley and I have to say am really happy how it is turning out so far
And here is the final setup and everything lines up prefect
Offline harkey25
« Reply #8 on: April 24, 2018, 12:05:44 PM »
And as for the turbo placement I was going to run Digi cars old turbo setup but due to me having a different subframe the turbo would sit well below the oil pan and I don’t want to run a scavenger pump so we are going to go ahead and make one
« Reply #9 on: April 24, 2018, 01:36:01 PM »
Looks like you're making good progress!
Offline shainiac
« Reply #10 on: April 24, 2018, 05:01:23 PM »
That's a creative tensioner setup lol.
Is that a GT4788? Should be rowdy.
BMW DCT Swap, Ronin 8.8" IRS
Offline harkey25
« Reply #11 on: April 25, 2018, 12:31:50 PM »
Close it’s a gt4718r should flow pretty well I will have to switch my fuel setup if I want to max that puppy out
Offline harkey25
« Reply #12 on: May 02, 2018, 11:17:39 AM »
Ok a little more progress has been made have a relay panel made
and test fitting the Holley and the display screen ( getting good at pulling the dash in and out )
Also we have made more for the fmic and radiator to fit with out having to move it to the trunk
Offline Ls2Rx7
« Reply #13 on: May 16, 2018, 02:33:40 PM »
coming along nicely jake! good job buddy. Is it going to be hood exit ?
Ls2, Tick Sns 2 cam, A&a c6 kit, LS3 top end, 760/640 @ 13.5 psi
Offline N2v8fcs
« Reply #14 on: May 16, 2018, 10:28:17 PM »
 8)
:drive:
