Cut a piece of 3/8 steel rod about 1.25" long (that length will hit the piston near centered in an LS) and round off one end to a convex hemispherical shape, then take an old spark plug, knock/grind the center and side electrodes off, and weld the flat end of your piece of rod to it. Take the exhaust rocker off the cylinder you are using, because it will open into the piston stop and either break it off or bend the valve if you dont.
